Torque Pro Ford 6.7L Extended PIDs
#1111
@sdetweil Hello. it seems like most of the PIDs are working. The one that really stands out is the Trans Temp. I see two in the list one is identical to the Coolant temp and the other is reporting 3 degrees which is the "6.7L". Any thoughts or suggestions?
Thanks in advance
Thanks in advance
hmn.. mine looks ok, TFT , third down on the left 'Transmission Fluid Temperature 6.7"
#1112
#1113
#1114
#1115
@sdetweil Not sure what happened I suppose it was "human error" I deleted and recreated and it appears to be reporting properly. The only other thing that I noticed was the speedometer was off by 3-4 MPH. Not a huge issue I was just going to remove it. I know my actual speedometer is off a little when I changed out the wheels and tires.
#1116
#1117
#1118
#1121
#1122
don't yah hate it when you research something, like torque pro and DSLR and all you find are posts YOU made 4 years ago!!...
still researching
well, that explains it... those two PIDS 220434 (Distance since last regen) and 22042C (Soot %)... do not exist on my truck..
wonder what/if anything, replaces them
still researching
#1124
Mine (the 6.7 pids) is not published there.
https://www.dropbox.com/s/m3fwxhqw1f...D4-19.apk?dl=0
also see
https://www.ford-trucks.com/forums/1...l#post18613029
also see
#1125
Got this now , how do i access it ?
also see
also see
