95 f150 parts
95 f150 parts
These are all the parts i have left to a 9 5 f150. Was 302 5spd long box 4x4 reg cab blue interior. If its not listed i do not have the part. Let me know what u need i will ship and i can get pics. Parts fit 92-96 f series
REAR CORNER TRIM-$15
STEEL WINDOW TRIM-$10
RADIATOR-$30
AC RADIATOR-$30
UPPER INTAKE-$30
FLYWHEEL-$15
FLEX PLATE-$15
BATTERY TRAY-$10
HOOD-$25
REAR SLIDER WINDOW-$30
FRONT DIFFERENTIAL 3-54 gears-$100 GLOVE BOX-$10
VALVE COVERS-$15
PSIDE PLASTIC MIRROR-$5
PSIDE VENT WINDOW-$10
CRANK SHAFT-$15
ROLLER CAM SHAFT-$10
ROLLER LIFTERS-$10
DOG BONES-$10
SPIDER-$10
MAIN JOURNAL CAPS-$15
GAS PEDAL-$5
CAB HARNESS-$30
FRAME HARNESS-$30
ENGINE BAY HARNESS-$30
DOME LIGHT-$5
GAS TANK SKID SHEILD-$5
ENGINE CRADEL-$30
TRANSFER-CASE-$100
MIDDLE SEAT BELTS-$5
HEATER BLOWER BOX-$15
AC STUFF-$50
BRAKE BOOSTER-$30
SUN VISORS-$10
HOOD HINGES-$10
HOOD SPRINGS-$10
ABS BOX-$15
F150 XL BADGES-$5
PSIDE DOOR WINDOW-$25
FAN SHROUD-$15
3RD BRAKE LIGHT-$5
DOOR HANDLES-$5
REAR VIEW MIRROR-$5
LIGHT SWITCH-$5
HILOW SIGNAL SWITCH-$10
WIPER COWL-$10
DISTRIBUTOR-$5
PUSHRODS-$10
TAILGATE TRIM PANEL-$10
PSIDE DOOR HINGES-$10
TAILGATE PARTS-$5
PSIDE DOOR WIRING-$5
BLACK PART DASH MOUNTS TO-$15 RUST FREE PSIDE RADIAS ARM-$40 RUST FREE RADIAS BRACKETS-$30 HEATER CONTROL-$5
BRAKE CALIPERS-$5
REAR SPRING BLOCKS-$5
DOOR GASKETS-$5
STEERING COLUMN SHEILD-$5
SEAT BELT SCREW COVERS-$5 STEERING SHAFT BOOT-$5
HOOD CABLE-$5
HOOD LATCH-$5
EBRAKE MECHANISM-$5
RADIATOR-$30
AC RADIATOR-$30
UPPER INTAKE-$30
FLYWHEEL-$15
FLEX PLATE-$15
BATTERY TRAY-$10
HOOD-$25
VALVE COVERS-$15
CRANK SHAFT-$15
ROLLER LIFTERS-$10
DOG BONES-$10
SPIDER-$10
GAS PEDAL-$5
CAB HARNESS-$30
FRAME HARNESS-$30
DOME LIGHT-$5
ENGINE CRADEL-$30
TRANSFER-CASE-$100
AC STUFF-$50
BRAKE BOOSTER-$30
SUN VISORS-$10
HOOD HINGES-$10
HOOD SPRINGS-$10
ABS BOX-$15
F150 XL BADGES-$5
FAN SHROUD-$15
3RD BRAKE LIGHT-$5
DOOR HANDLES-$5
REAR VIEW MIRROR-$5
LIGHT SWITCH-$5
WIPER COWL-$10
DISTRIBUTOR-$5
PUSHRODS-$10
TAILGATE PARTS-$5
BRAKE CALIPERS-$5
DOOR GASKETS-$5
HOOD CABLE-$5
HOOD LATCH-$5
EBRAKE MECHANISM-$5
