1987 F350 front turn signals not working
Howdy all... I have a old work truck/dump 350 and the front turn signals do not work and either do the break lights. I have not tried to replace the breaklight switch yet or the multi function switch in the steering column as of yet trying to see if it's something more simple then that. I also have checked all bulbs and fuses and those are good. The lights turn on in the front but will not blink. Then I am sorta clueless regarding the break lights. Oh and before I forget it also has no reverse lights.
Also if you have a nice picture of the fuse box for a 87 350 I would appreciate it for my records.
Any help appreciated.
Matt
Matt
Received 3,118 Likes
on
do the rear blinkers work?
if no blinkers work, the lights just stay on solid, try changing the flasher. it is in the fuse box.
if no rear lights at all, i would say it is the blinker switch in th column is bad. if the rear blinkers come on than i would try jumping the brake light switch and see if the lights come on.
the brake lights may also just be an out of alignment switch.
on
@subford correct the front lamps turn on fine however will not flash. The rear flash now that I have them grounded correctly. I am thinking maybe the flasher is bad in the fuse box? Reason I say this is my hazords do not work either. However yes the blinkers do show up on the dash.
@crew there is no attitude here please only reply on my thread if you have something helpful to actually say rather then complaining that I have an attitude which is not true.... Frustrated at crazy electrical problems would be more like it.
Thanks subford for your help so far.
Matt
Matt
@subford that diagram you posted does it matter that it's for a 150? This is the first Ford I have owned and my first truck so I have not a clue. I am happy though that I was able to get the rear turn signals working along with the running lights in the rear. I just pulled the flasher from the fuse box and I am going to replace this to see if this fixes my problem.
Matt
Matt
