Body Cocked
Old Jul 9, 2003 | 08:58 AM
dlarson's Avatar
dlarson
Body Cocked
DlarsonI thought that would get our attention!
My 1951 daily night cruiser (I drive it when I get home every day) is leaning to the passenger side one half inch. I'm measuring from the bed on each side to the cab. It doesn't seem to be a bent frame, do you think new bushings on each side will fix it? I'm kind of confused. I can push the cab into the right position but it just goes right back. Maybe I can tigthen some bolts.
Old Jul 9, 2003 | 09:11 AM
dlarson's Avatar
dlarson
Body Cocked
I have recently painted the grill gloss black and thinking about adding some retched gloss black flames.
Old Jul 9, 2003 | 09:34 AM
Jag Red 54's Avatar
Jag Red 54
Body Cocked
The body on my 54 was tilted to the pass side. It turned out that the bushing on the driver side rear corner was missing! Good luck, John
Old Jul 9, 2003 | 10:08 AM
DS02F250's Avatar
DS02F250
Body Cocked
yep, sounds like bushings or cab mounts. Should consider replacing both sides so the are even. I just did the same on my front suports (by the radiator) to even up my front fenders on my '59... WORLD of difference.
Daryl
Old Jul 9, 2003 | 01:01 PM
Aekisu's Avatar
Aekisu
Body Cocked
<br>
I'm working on a 56 frame right now. The cab mount brackets are cracked near the top of the bracket. Putting in new bushings will not fix my condition. The bracket will need to be releveled and welded.
Perhaps you have the same type of problem.
Old Jul 9, 2003 | 03:10 PM
dlarson's Avatar
dlarson
Unhappy Body Cocked
Wow, Scary...........I'll check. Thanks for the heads up.
Dlarson
