Door seal question
Old Jun 25, 2014 | 12:00 PM
BigBlkEX's Avatar
BigBlkEX
Door seal question
Will a door seal from a F250 crew cab driver rear side work for a Ex.
Old Jun 25, 2014 | 12:01 PM
mecdac's Avatar
mecdac
Different shape door, probably not.
Old Jun 25, 2014 | 11:20 PM
superdave02f552's Avatar
superdave02f552
I have to disagree about the shape seeing as I have a f250 door on my x now at least that's what the paint marker from the junk yard said
Old Jun 25, 2014 | 11:25 PM
BigBlkEX's Avatar
BigBlkEX
Thank you for the info!
Old Jun 25, 2014 | 11:31 PM
Psyclopse's Avatar
Psyclopse
I don't have first-hand knowledge to answer this, but I will add this-
When you do a lookup for an Excursion rear door on car-part.com, all you get are Excursion results. Similarly, when you look up the same door for a crew-cab Super Duty, you get 250/350 SD results only. Do the same search for a front door, and you'll get mixed SD/Ex results. Car-part is usually very good at producing interchange results, and for whatever reason, they seem to think the rear doors are different between an Ex and a CC...
Old Jun 26, 2014 | 12:09 AM
warrens73's Avatar
warrens73
^^^^ What he said. I own both, a 2005 Ex and a 2007 F250 crew. The rear doors are very different. The rear edge of the F250s door is almost straight where the Ex's door is more rounded.
Old Jun 26, 2014 | 12:18 AM
warrens73's Avatar
warrens73
Old Jun 26, 2014 | 12:22 AM
Psyclopse's Avatar
Psyclopse
^^^^ To add to what warrens73 said, we can conclude right in this thread that the doors are different...
1) look at my dad's crew cab in my signature pic- the rear door window is darn near perfectly square.
2) now scroll up to superdave02f552's post (post #3) and look at the Ex in his user icon pic- the rear edge of the window angles forward as it goes up. The yard must have mis-marked the door or assumed they were the same...
EDIT- warrens73 beat me to the punch! haha
Old Jun 26, 2014 | 12:56 AM
robert_l_ross's Avatar
robert_l_ross
Originally Posted by warrens73
Looks as if maybe the bottom of the window is also wider, making the entire door width bigger on an Ex than the 250/350. That would make the entire length of tubing different, so I would suspect that they wouldn't fit.
...thought though...
When I replaced my fronts, they were maybe 3/4" too short. I cut a 3/4" piece off of the old one and slipped it in along the bottom.
Wondering if the length of the 250/350 door seal is similar to an Ex (say, within 3-6"), and you really couldn't find one for the Ex, could you just do the same (replace it and fill in the gap with a section of the old seal)? Should be more than enough new seal to cure the 'rattle' of the doors.
Old Jun 26, 2014 | 06:30 AM
BigBlkEX's Avatar
BigBlkEX
My thoughts exactly! Thanks everyone for all the good info!
Old Jun 26, 2014 | 11:04 AM
superdave02f552
i wonder where they got the f250 on my door from?
maybe just a simple typo on there behalf and they new better.
thank you for the direct photos to show the diff
Old Jun 27, 2014 | 11:59 AM
Turfzilla's Avatar
Turfzilla
Body is identical from the rear end of the front door forward.
Old Jun 27, 2014 | 12:41 PM
mecdac's Avatar
mecdac
Yes, the "B" pillar.
Old Jun 28, 2014 | 12:50 AM
Psyclopse's Avatar
Psyclopse
We need to keep thinking of ways to continue the rear door discussion, so I have an excuse to keep looking at the black Explorer in the example above...
Old Jun 28, 2014 | 04:01 AM
warrens73's Avatar
warrens73
^^^^^ I like this guy. Lol
