Code p0430
Old Jun 23, 2014 | 11:01 PM
05expy53l3v's Avatar
05expy53l3v
Code p0430
Hi how every one doing ? I just bought an 05 Expedition 5.4L 3v 4x2 180k miles, truck run extremely smooth, gas miles is normal, it does having that ford tick at low rpm , I drove 600 miles trip couple day ago and add a bottle of chevron fuel injector cleaner , today the CEL came on and I pull the code, show up 4 code, all show p0430 . Any idea ? the truck run fine and smooth at the moment, should I be fixing this problem right away ?
sorry English is my third language , please excuse my grammar , thank you and have a wonderful day.
Old Jun 23, 2014 | 11:14 PM
lv2race's Avatar
lv2race
The tick may be an exhaust leak causing the code. Check the link............
OBD-II Trouble Code: P0430 Catalyst Efficiency Below Threshold (Bank 2)
Old Jun 23, 2014 | 11:17 PM
05expy53l3v
What place should I start check for exhaust leak first ?
Old Jun 24, 2014 | 07:43 AM
projectSHO89's Avatar
projectSHO89
Driver's side exhaust manifold. Look for broken studs that allow exhaust leaks past the gasket between the manifold and the head.
If there is no exhaust leak there, then there is a strong chance that the catalytic converter on that side is dead. More diagnostics will need to be done before reaching that conclusion, though.
Old Jun 24, 2014 | 10:04 AM
05expy53l3v
I havent check yet, but let say if the exhaust manifold bolt broke, how much the shop charge to fix that, also if it is the catalytic is plug up or dead, how much for the shop to put in new one ?
can I drive with 1 bad catalytic ? I really busy lately and cant take to the shop until 2-3 more week.
Old Jun 24, 2014 | 11:24 AM
alloro's Avatar
alloro
Could be a bad downstream O2 sensor also. (Driver's side after the cat.)
Old Jun 24, 2014 | 11:27 AM
05expy53l3v
I see some steam coming out for 2-3 second when I first crank in the morning, then the steam dissappear . Worth to let you guy know.
anyway to complete test if o2 or cat are bad ? I dont want replace part that is not bad.
Old Jun 24, 2014 | 11:29 AM
alloro's Avatar
alloro
I see some steam coming out for 2-3 second when I first crank in the morning, then the steam disappear.
Steam from where, under the hood, under the vehicle, out the exhaust?
Old Jun 24, 2014 | 11:34 AM
05expy53l3v
out the exhaust , look like just cold morning condensation.
Old Jun 24, 2014 | 04:19 PM
alloro's Avatar
alloro
Could be a bad head gasket on that side. That would cause both the steam out the exhaust and throw the catalyst out of range.
Old Jun 24, 2014 | 04:48 PM
05expy53l3v
lol slow down.
Old Jun 24, 2014 | 06:44 PM
05expy53l3v
BTW bank 2 is driver side or passenger side ?
Old Jun 25, 2014 | 09:55 AM
alloro's Avatar
alloro
Bank 2 is the driver's side. Bank 1 is always the side with the #1 cylinder, which in this case is on the passenger side.
Old Jun 25, 2014 | 11:09 AM
05expy53l3v
thanks.
Nathan511
1997 - 2003 F150
Dec 16, 2018 07:32 PM
Bluegrass 7
1997 - 2003 F150
Jan 27, 2018 11:41 PM
mjbll
1997 - 2003 F150
May 31, 2011 09:48 AM
longh2o
Mar 3, 2010 07:34 PM
