Ran Her Empty
Old Jun 23, 2014 | 12:35 PM
los341's Avatar
los341
Ran Her Empty
Yesterday while towing my rig down the highway, I unintentionally ran out of fuel, about a quarter-mile from the station (first time I've ever done this ). I brought back a 5-gallon jug of fuel to pour in, turned the ignition on and off 10 times at 30-second intervals, then made 4 start attempts before she ran. Drove to the station and filled up the rest of the way and added the usual 6 oz of PM-22A.
I'm a little concerned about the HPFP. Does anyone know if running out of fuel has been known to cause damage or excessive wear? Any advice is appreciated!
Thanks,
Carl
Old Jun 23, 2014 | 12:58 PM
Sgt93's Avatar
Sgt93
I think looking at the HPFP wrong causes damage.
Old Jun 23, 2014 | 01:47 PM
Thom12's Avatar
Thom12
Is there any right way to look at them?
Old Jun 23, 2014 | 05:28 PM
System's Avatar
System
Prolocutor
Only time will tell but odds are you're fine.
Old Jun 23, 2014 | 06:37 PM
2ndStroke's Avatar
2ndStroke
I never make eye contact....
Old Jun 23, 2014 | 11:36 PM
kper05's Avatar
kper05
All I know to recommend is to check the filter pleats next time you change fuel filters.
Was the computer at 0 MTE or did it die before 0?
I've been as far as 24 MTE and I'm to chicken to repeat it although even then full was less than 22 gallons.
Old Jun 24, 2014 | 12:41 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Never have run mine clear out but I've filled it a couple of times at a shade over 36 gallons, that pretty much empty for a 37.5 gallon tank.
Old Jun 24, 2014 | 06:59 AM
System's Avatar
System
Prolocutor
I've run both my 09 and current truck on 0 to empty for 25+ miles. They computer is WAY off to protect us stupid Americans. In all cases I've always had 2-4 gallons left in the tank.
Old Jun 24, 2014 | 08:06 AM
jonrjen's Avatar
jonrjen
Wow, to me 1/4 tank remaining is empty. I just can't bring myself to allow the fuel gauge nettle to drop lower than that.
Old Jun 24, 2014 | 08:10 AM
System's Avatar
System
Prolocutor
Well, when you know it's off by around 1/5th, it's not much of a risk...
Old Jun 24, 2014 | 08:25 AM
Big-Foot's Avatar
Big-Foot
In tank fuel pumps are typically cooled by the flow of fuel through them and around them. GM pumps are famous for failing when run below 1/4 tank. I've replaced a half dozen of them in my own trucks before we just adopted the 1/4 tank = Empty rule..
I would hope that there was still enough fuel left in the system that the high pressure fuel pump's internals were lubricated.. Also I would think that the ECU or other fuel management programming would be set to minimize the run time of the pump(s) without pressure in the system.
Old Jun 24, 2014 | 08:29 AM
System's Avatar
System
Prolocutor
LOL you guys are nervous about everything. Under 1/4 tank = THE SKY IS FALLING... I couldn't live that way. Still haven't drained my fuel filter either... LOL. To each their own though.
Old Jun 24, 2014 | 08:35 AM
Big-Foot's Avatar
Big-Foot
Nice of you to throw some of us under the truck just because you've been lucky so far...
Wishing you continued good luck.. If not so lucky, we'll stop and help you out on the side of the road...
Old Jun 24, 2014 | 08:51 AM
los341's Avatar
los341
It was at 0 MTE but I'm not sure how long because clearly I wasn't paying close enough attention. I got a "Low Fuel Pressure" warning, followed by "Reduced Engine Power" about 2 seconds before it died.
Filling up, it took 36.1 gallons total. So I don't see how Ford's 37.5 gallon claim can be true, unless they're counting unusable fuel in the tank.
Big-foot, not sure if you're aware, but our trucks don't have an in-tank fuel pump. The low pressure pump is in the DFCM.
Thanks all for the advice and recommendations!
Carl
Old Jun 24, 2014 | 09:01 AM
Big-Foot's Avatar
Big-Foot
Hi Carl,
I'm new to this generation diesel system. My past experience with diesel was in the late 90's and goes back to the 40's..
DFCM?
