Sponsored by: Real Truck
Hydroboost bypass
Old Jun 22, 2014 | 11:38 PM
TEVMAN's Avatar
TEVMAN
Hydroboost bypass
I tow a 1999 Ford F-250 diesel behind my Motorhome. It appears that when the tires turn while being towed there is back pressure creating a leak at the Hydroboost master cylnder. I would like to put a manual valve where the power steering pressure hose connects to the short metal line on the master cylender that would allow me to open the pressure line to the return line on the master to the power steering pump. Can you assist me with line size connections and a possible valve salection? Do you see any problem with this other than forgetting to switch the valve when I am ready to drive? I would still have power breaks, I think.
Old Jun 23, 2014 | 06:58 AM
Tom's Avatar
Tom
Hi Tevman,
That's gonna be a tough one to answer. Are you using some kind of setup to actuate the brakes on your truck while it's being towed?
Old Jun 23, 2014 | 03:42 PM
TEVMAN's Avatar
TEVMAN
Towing Configuration
I probably should but am not using a suplamental braking system at this time. My thought is that if I can relieve the pressure from only the power steering pressure hose back to one of the low pressure return hoses it should not affect the brake side of the Hydroboost. Is this a bad assumption?
gman97005
Oct 23, 2016 08:25 PM
Blind Driver
Sep 21, 2015 06:48 AM
randyj68
Jun 29, 2014 07:53 PM
tbugher62
Jun 5, 2013 10:20 AM
Ryanr
Mar 27, 2011 08:49 PM
