435 swap
Old Jun 22, 2014 | 05:12 PM
Kymudder150's Avatar
Kymudder150
435 swap
I have a 95 f150 im runnin 36.5 tires and and i want to swap from a 5 speed to a np 435 for the granny low 1st gear what do i need to pull it off?
Old Jun 22, 2014 | 07:54 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You're gonna have to do something about the linkages. As you probably know, the 435 is all manual linkage, where as your current ZF5 is hydro. You might be able to rig up a mount to mount the slave on the trans to actuate the fork.
I have a ZF5 and a 435 sitting in my shop floor. I have to decide which one I want to put in my '88...
Old Jun 22, 2014 | 07:58 PM
Kymudder150
Ive got the mazda 5 speed i thought about swappin in a zf but i want that super low 1st gear
Old Jun 22, 2014 | 08:28 PM
BruteFord's Avatar
BruteFord
Thank you,
Moderators
Old Jun 22, 2014 | 08:45 PM
Kymudder150
Well my reasoning behind the 4 speed ive heard its pretty bullet proof and with the low tranny gears i could run a more reasonable ring and pinion like a 456 or so for my inline 6 to turn them tires and i dont need overdrive but i need to remain daily driveable so i wanna stay away from a doubler plus i can get a 435 way cheaper and easier than a zf
Old Jun 22, 2014 | 08:58 PM
BruteFord's Avatar
BruteFord
Thank you,
Moderators
Old Jun 22, 2014 | 09:08 PM
Kymudder150
Well i was countin on runnin 488s and im never fooled with doubled transfers just seems less user friendly on a dd also im plannin on doin a engine swap before too long and the little mazda 5 speed wont hold up to much power and id rather change bell housings on the 435 than a whole new zf
Old Jun 22, 2014 | 09:10 PM
Kymudder150
If its pretty road friendly a doubler might be the way i go
Old Jun 22, 2014 | 09:17 PM
BruteFord's Avatar
BruteFord
Thank you,
Moderators
Old Jun 22, 2014 | 10:17 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You won't be able to tell you have a doubler on the road. You leave both t-cases in 2-HI. A doubler is only there when you engage it...
Old Jun 22, 2014 | 11:31 PM
f100beatertruck's Avatar
f100beatertruck
83-87 4spd trucks used a hydro setup with an external slave and separate bell housing. My 86 Supercab has a T18 and the NP435 will bolt directly to that bell... So it shouldn't be too hard to swap.
mustang_gt_350
Aug 25, 2015 03:03 PM
lvin4jc
1978 - 1996 Big Bronco
Dec 28, 2014 12:06 AM
geo_84
Jul 28, 2011 07:46 AM
Nile911
Nov 23, 2005 01:43 PM
Paul Crowther
Nov 24, 2004 09:17 PM
