I bought the truck as is with some mods. Havent made any changes in 4 yrs it has run well until recently. It seems now the edge is losing power and turning off ?? Anyone else have anything like this?
welcome to FTE.
i cant answer your question, but someone may be along sooner or later that may be able to.
most of us use chips, and stay very far away from edge products.
connection maybe? I don't know which fuse it is, but there is one for the OBD II connector. I've only seen it happen once, but I had a fuse that only half popped and caused some intermittent issues with the power windows on my saturn.
The problem happened a couple of times over several weeks, it would cause it to stumble and stall etc
then after a few attempts to restart it would start and run, not like normal but atleast smoothly. Then after a bit the edge would suddenly light up and come on and it would return to normal. Last night I went to the car wash I did not open the hood I only washed down from underneath nothing major just spray from the sides. On restart no edge barely run, chug etc then finally it started and ran like before without the edge. I got it home the edge did not come back on. I agree its starting to sound like a connection problem.
Im going to start looking there.
As for a list of the mods, Im still trying to sort out exactly what it has, hell I just figured out last week the turbo has been changed I have no idea what it is other than it says garret on it
