If just needing about 4 inches of lift- what's the easiest way on a 05 ex?
What are you hoping to get from your lift (besides 4" more ride height )?
I wanted enough room to run 35"s and a beefier suspension to allow the EX to tow heavy with as much control as possible. I went with an X/B spring swap, modded both front and rear springs with additional leaves and installed the taller F-350 rear blocks. Gained 3 7/8" up front and 4.5"+ in the rear, now it sits nearly level with a very heavy tongue weight trailer and the stronger springs have vastly improved it's towing manners.
