Has anyone installed Borla on a 03 F250 SuperDuty?
I just purchased the catback single side exit catback and would like some feedback from others about the sound, performance, etc.
Sound: not much louder than stock. A little more "roar" to it.
Fit & Finish: should be excelent.
Power: no noticeable change with just the cat-back
Tip: I made 2 parallel cuts in the stock tubing at the clamped joint and spread open the tubing to get it to come apart. You can also just use a sawzall and just cut it off.
I put a dual out the side Borla on my buddies 01 SD SC and it was very simple to in stall. We backed the truck up on ramps droped the spare tire and installed it in about 45 min. It's a quality engineered item and very installer friendly.
