Delores
Old Jun 19, 2014 | 09:54 AM
Delores Carter's Avatar
Delores Carter
Delores
My boyfriend has a 1985 f 350and wants to put bucket seats...how do we find the right seats..
Last edited by Delores Carter; Jun 19, 2014 at 09:56 AM. Reason: put wrong number...
Old Jun 19, 2014 | 10:01 AM
SVTDriver97's Avatar
SVTDriver97
Start here:
Electronics, Cars, Fashion, Collectibles, Coupons and More | eBay
Old Jun 19, 2014 | 10:11 AM
ctubutis's Avatar
ctubutis
Welcome to FTE.
You can also ask Google:
Let me google that for you
Old Jun 19, 2014 | 12:04 PM
Gary Lewis's Avatar
Gary Lewis
Dolores - Welcome to FTE. Don't let those guys get the wrong impression about FTE.
I think the question you are asking is one I've been working on myself - what buckets to use and how to mount them. Part of the answer depends on the type of cab the pickup has. If it is a super or extended-cab then it probably came with buckets so it must be a standard cab. If that's true then there are at least two problems. The first is the bucket seat to use, and I went with Bronco buckets. But it turns out Ford had two different kinds of buckets, short and tall-backed. I went with the taller ones (shown here)and I believe I'm going to have minor problems with the back hitting the rear window, so I would recommend the short ones.
The other problem is mounting the buckets. The standard cab has only the outside holes for the bench, but buckets need outside and inside for each bucket. And the cab floor is anything but level or uniform, so bolting them in isn't easy. Some have just drilled holes and shimmed with washers, but I don't think that is a good approach as the inside holes won't be reinforced like the outside holes. However, there is a bolt-in solution. In the 90's Ford had a bucket seat and console arrangement that bolted to a mount, which then bolted into the outside holes in a standard cab. If you can find that setup it'll be a bolt-in solution. And you can see one of those mounts in the thread above.
Old Jun 19, 2014 | 12:15 PM
ctubutis's Avatar
ctubutis
Yes, I was only showing how to find (replacement) bucket seats, there are a few different methods people here have used (including aftermarket seats) and, as Gary said, the answer is usually: "It depends."
Wish I could come up with one of those 90s mounts but I keep forgetting to look any time I run across a 90s truck in the JY... if I can find one, I'll use it instead of the bolt/fender-washer/bracket stuff I'm currently using.
Old Jun 19, 2014 | 12:16 PM
Delores Carter
Thank you so much for the information. ..I will pass it on to my boyfriend
abosely
13
Dec 12, 2015 11:03 AM
jaluhn
19
Feb 14, 2012 01:12 PM
vinmicmor
Feb 7, 2010 02:05 PM
Brian794x4
Mar 26, 2007 08:58 AM
Steven@nd
Sep 19, 2004 07:59 PM
