Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford F600 Wiper Arm & Pivot Shaft
Old 07-01-2014, 06:46 PM
BADDBOYY21's Avatar
BADDBOYY21
BADDBOYY21 is offline
I was installing a new wiper motor in my 1986 Ford F600 today. When taking the old motor out I could not get the bolt loose on the shaft of the motor. I had to take the linkage arms off so I could get the motor out and remove the bolt. When doing that I damage one of the bushings on the motor side of the arm.
My question is, can you replace that bushing or does the whole arm have to be replaced? No local parts store had any info on that bushing. I think I have located the correct part numbers for the complete arms. E0TZ-17566-A and E0TZ-17567-A. NOS Parts LTD. wants $80 a piece plus shipping. Does any one know where I can find them cheaper?
Any advice on how to install the arms back on to the motor shaft without damaging the new bushings?
Thanks,
Shawn
Old 07-06-2014, 09:20 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
My question is, can you replace that bushing (no) or does the whole arm have to be replaced? Yes.
The correct part numbers for the Arm & Pivot Shaft Assy: E0TZ-17566-A Right ~ E0TZ-17567-A Left / Obsolete
1980/86 F100/900 & Bronco / 1987 F150/900 & Bronco before production date 6/87.
When the 2nd digit of the part numbers prefix is a zero, it can also be typed as the letter O.
EOTZ-17566-A =
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201 (as E0TZ).
EOTZ-17567-A =
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371. (as E0TZ).
DON SANDERSON FORD in Glendale AZ has 2 = 623-842-8643.
NOS PARTS LTD has 3 (as E0TZ).
Redworks
04-17-2016 04:48 PM
BADDBOYY21
Large Truck
06-25-2014 10:14 PM
cbass139
05-16-2013 11:08 AM
Rob C
01-22-2008 12:25 AM
Quick Reply: Ford F600 Wiper Arm & Pivot Shaft
