Failure Mode Effects Management
Old Jun 18, 2014 | 01:02 PM
AMTCM's Avatar
AMTCM
Smile Failure Mode Effects Management
Two days ago while leaving Church 2005 Expedition (EB) began to emit white smoke from exhaust and smelled of gas. Assumed it wasn't firing properly on all cylinders. The car belongs to another person who drove it home. Next day the car wouldn't start. I towed it to my garage to take a look at it. The starter makes winding noise but does not enage flywheel. I realize this problem is not related to previous problem. Battery is fine so I am thinking solenoid or starter. Then neighbor tells me that Ford has a Failure Mode which protects system and that it why it doesn't crank. I have not been able to find anything on internet and so I thought I would try you Ford experts. I am a serious mechanic but I usually only work on old cars, airplanes and helicopters. I don't have any experience with trouble shooting EI Coil Over Plug Ignition Systems but I understand the engineering and theory. Ok so any suggestions...or shall I give up and tow it to a dealer. The goal is to save the nice church lady hundreds of dollars in repair bills since I would do the wok pro bono. Any assistance greatly appreciated...Thanks
Old Jun 19, 2014 | 01:26 PM
lv2race's Avatar
lv2race
Get a code reader and check for codes.
Old Jun 19, 2014 | 01:45 PM
alloro's Avatar
alloro
White smoke out of the exhaust (steam from coolant) is usually an indicator of a blown head gasket.
Old Jun 19, 2014 | 02:07 PM
AMTCM's Avatar
AMTCM
Update
Update: I replaced starter and it starts and drives. White smoke but no apparent cooling issues. Idles somewhat rough. I am heading to autozone for a code reading next. Thanks for your replies.
Old Jun 19, 2014 | 03:47 PM
AMTCM's Avatar
AMTCM
Ok I put in the reader and the Codes are P2198 and P2195. Car runs rich, hard to start and idles poorly like it wants to stall at red lights. No Overheating.
Old Jun 19, 2014 | 08:58 PM
lv2race's Avatar
lv2race
Have you checked for coolant in your oil and vice-versa?
Read the two links thoroughly and check each item as you go.
P2195 O2 Sensor Signal Biased/Stuck Lean (Bank 1 Sensor 1) DTC
P2198 O2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 1) DTC
Old Jun 20, 2014 | 06:40 AM
projectSHO89's Avatar
projectSHO89
Sounds like a stuck injector. Common problem with the 05s. See TSB 05-13-4.
FMEM is not an issue with this occurrence.
Old Jun 20, 2014 | 10:11 AM
alloro's Avatar
alloro
A compression test is the way to go. Nothing will solve this problem if it's a blown head gasket, except to deal with the head gasket. Excess fuel such as from an injector sticking open will create black smoke, and oil burning will be blue or grey smoke.
84 f250 6.9
59
Dec 28, 2009 08:52 AM
Lead_Foot
Jul 23, 2006 09:51 PM
jb1390
35
Feb 16, 2006 10:19 PM
GunNut
Jul 23, 2004 06:57 AM
bphillips777
Jul 7, 2003 10:29 AM
