Identifying a lift kit?
Is there anyway to tell the manufacturer of this kit? I haven't seen any markings on it as far as part numbers or anything, but I havent looked that closely yet, either. It had skyjacker shocks on it (the rears were installed upside down--guess they couldnt read the "this end down" markings), and I just put a brand new set of em on there (improved ride considerably).
I just wanted to try and figure out the kit manufacturer, in case I run into trouble with it later on down the road.
If pics will help, just say so--I'll get some posted
Thanks,
Jim
If the parts are black, it's hard telling. You'll need to get under the truck with a good flashlight and inspect the drop brackets and such for a manufacturers stamp. There should be something somewhere. If the shocks were installed as part of the kit, they should also be stamped with the lift manufacturer's name and may be easier to see.
A couple color guidelines:
Red is generally Rancho
Yellow is generally Superlift
Blue is generally Explorer ProComp
Gray or Hammertone could be any of two or three others.
All these manufacturers also sell black
HTH,
Larry
Good luck,
Larry
