Temp spread
Old Jun 16, 2014 | 01:22 PM
cornstar6207's Avatar
cornstar6207
Temp spread
I put a Scanguage on my 04 250, so now that I have some info, I have questions. What sort of temp spread should I be seeing on eot vs. ect? Right now at 70 mph, not loaded, the eot is running about 10 degrees over ect. At 60 mph, it's about 6 over. At idle after driving it's about 3-4. Thanks for any and all replies and opinions.
Old Jun 16, 2014 | 01:26 PM
Money-Pit's Avatar
Money-Pit
Your "temp spread" numbers look great...what were the actual ect & eot numbers?
Old Jun 16, 2014 | 02:04 PM
cornstar6207
188 ect, 198 eot at 70 mph. At 60 it was 188 ect, 194-195 eot.
Old Jun 16, 2014 | 02:23 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...............Perfect!
Old Jun 16, 2014 | 03:11 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Muy bueno temp numbers.
Josh
Old Jun 16, 2014 | 03:55 PM
Splash67's Avatar
Splash67
Very good...curious to hear what they are when you are towing....
Old Jun 16, 2014 | 04:34 PM
cornstar6207
Last time I towed my cattle trailer, I didn't have my scanguage yet. I did pull the boat with the guage hooked, but the numbers were the same.
Old Jun 16, 2014 | 06:42 PM
spdmpo's Avatar
spdmpo
At least he didn't call the temps "deltas."
Old Jun 16, 2014 | 07:00 PM
cornstar6207
horsepower
another scanguage question I have is how many horsepower can I expect to see? And at how many psi of boost?
Old Jun 16, 2014 | 10:07 PM
KIDkiser's Avatar
KIDkiser
Scangauge doesn't give you any horsepower,it's not a tuner,just a gauge.
Old Jun 16, 2014 | 10:21 PM
Bullitt390's Avatar
Bullitt390
SG2 doesn't have PID's for PCM reported horsepower and torque?
Josh
Old Jun 16, 2014 | 10:28 PM
jswartz84's Avatar
jswartz84
Josh
Yes, it does
Old Jun 16, 2014 | 10:36 PM
cornstar6207
Yes it tells me what the hp and boost psi are. I was just wondering what is normal with a stock engine. You know, what kind of hp can I expect at wot, and what kind of boost. That way I know if my truck is performing in the normal range of expected hp and boost.
Old Jun 17, 2014 | 09:33 AM
JeffMc202's Avatar
JeffMc202
This post makes me feel good about my numbers. I have the same "spread" while towing my boat. Other than the ECT dropping at a faster rate after a hill climb, I'm at 10 degrees going up and down the hills of the eastern Ozarks in Missouri at about 85 degrees outside temps. Boat is a 2006 Procraft 215 Combo. Boat, Motor and trailer cant be more than 4K. Went through a storm front during the last tow and the outside temp dropped into the low 70's with rain. Was showing about six to eight degree spread then. Using Torque for android :-)
Old Jun 18, 2014 | 11:57 AM
jgdrcr's Avatar
jgdrcr
What should be the max eot and ect temps when towing and not towing without doing any damage?
