Alternator problem Still Need Help
Old Jun 16, 2014 | 10:57 AM
tlcsr66's Avatar
tlcsr66
I am on my second alternator in 2 days. I'm stuck in South Carolina. If anybody has any guidance I can really use it right about now.
I hooked a gauge up so I can monitor the alternator. It was charging for about three hours and then it just quit. I had the parts store check both alternators and they checked out fine. I put the replacement alternator on anyway. The new one doesn't seem to be charging either. The truck runs on battery and the further I go the lower the volts drop.
Any help please I'm at a loss to what the problem is.
Old Jun 16, 2014 | 05:48 PM
BigBlkEX's Avatar
BigBlkEX
You check all cables. No corrosion, all tight? Just a thought.
Old Jun 17, 2014 | 01:55 AM
LWW's Avatar
LWW
What year and engine is your Ex? I'm going to guess it's a bad alternator to battery connection.
Old Jun 17, 2014 | 07:46 AM
tlcsr66's Avatar
tlcsr66
Thanks for the replys. I was so frustrated I took the truck to the dealership. They had it in the bay for all of 15min. It was a loose wire on the positive batt terminal...grrrrr!
I was back up and running and have had no problems since. The service manager apologized for charging me $30, I just laughed and handed him the money with piece of mind
Old Jun 17, 2014 | 09:22 AM
Mr.Nobody's Avatar
Mr.Nobody
Glad to hear you're back on the road. That is just like my dad always says, "I'm not charging you to turn the screw, I'm charging you because I know which screw to turn". Sounds like $30 well spent, and knowledge gained.
Old Jun 18, 2014 | 12:37 AM
BigBlkEX's Avatar
BigBlkEX
Glad you got it fixed, that sigh of relief when it was something simple priceless.;-) I knew it sounded like a loose wire.
KirstenxMarie
Nov 18, 2022 07:50 PM
Knucklesmd
2004 - 2008 F150
Nov 14, 2015 09:30 PM
jayro88
Dec 13, 2013 06:10 AM
r0n1n
Electrical Systems/Wiring
Jun 27, 2009 08:53 AM
pgebhart
Mar 14, 2003 07:06 PM
