3in Body lift and 33x12.50R15 A/T's? yes/no? Performance issues?
Old 06-16-2014, 09:08 AM
TylarCole's Avatar
TylarCole
TylarCole is offline
Should I add a 3in Body Lift and sit her on 33x12.50R15 A/T's?
Ive got the money, I just need some opinions.
Its not my daily driver so gas mileage Isn't my concern.
Any body know of any major performance issues with this?
Old 06-19-2014, 05:32 PM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
You would probably want to add a few more dollars for new gears. The larger tires will make the acceleration slow down, but regearing will keep it performing correct.
For example:
Starting with a 28" tire with a 3.55:1 ratio you would need about a 4.11:1 to be equal.
And yes it would look nice...who doesn't like a lifted truck with larger tires
Old 06-20-2014, 01:06 PM
TylarCole's Avatar
TylarCole
For example:
It has 31''s on it now, im not sure what to change the gears to. How much would that cost? Would I just take it to a mechanic to get it done or something?
Old 06-23-2014, 11:28 AM
Turbo Dog's Avatar
Turbo Dog
I think it cost me about $700 to buy a limited slip, new gears, and have it installed. The limited slip was a little over $400 if I remember right. I had it done at a shop because it didn't cost much more than buying a pinion depth setting tool.
You can use this equation to figure out what rpm you will need at a certain speed. I built the equation to calculate top speed, but you can just change the RPM parmeter to see what speed it will give you. For example put in 2500 for RPM and then play around with the gear ratio until you acheive an acceptable highway speed. Tire Diameter is in inches.
MPH = ((RPM X 60)/ Gear Ratio) X ((Tire Diameter X Pi) / 12) X5280
If you want it in an excel spreadsheet just PM me your email address.
andres0517
1999 to 2016 Super Duty
01-07-2013 04:53 PM
995.4SD
02-27-2007 06:53 PM
william_ace
10-28-2003 09:44 PM
Wakeboarder141
1978 - 1996 Big Bronco
10-13-2003 07:47 AM
texashottie
10-09-2003 11:48 PM
Quick Reply: 3in Body lift and 33x12.50R15 A/T's? yes/no? Performance issues?
