radio only plays for 10 minutes?
I recently bought a 2013 F150 xlt.I'm trying to listen to the radio with the truck not running(nascar race).The key has to be on and the doors open so i can hear the speakers.After about 10 minutes the radio shuts off and the display says low battery.My 2010 never did this.I tried putting a trickle charger on the battery and nothing changed.Any ideas?
I'm not sure what you mean. I just checked on my truck, and there are four positions on the ignition switch.
Off (where you can insert and remove the key), ACC, Run, and Start.
They aren't labeled, but when the ignition is in the second position, (that I call ACC), the radio turns on, and I assume it stays on.
With the key removed, I have confirmed that the radio only stays on for ten minutes on my truck.
I'm pretty sure I wasn't counting twice.
Described a different way, here's the positions
1) Key not turned, can be insterted and removed freely
2) Radio comes on, dash gauges and warning lights NOT lit
3) dash gauges and warning lights lit
4) starter engaged, (this position is momentary, and when released, key goes back to position 3).
what do you guys have?
http://awesomegifs.com/wp-content/up...razy-pills.gif
page 195 of the 2013 owner's manual, 3rd printing:
the ignition switch has 4 positions.
A - Off
B - Accessory
C - On
D - Start
Accessory allows the electrical accessories such as the radio to operate without the engine running. Note: do not leave the ignition key in this position too long. This could cause your battery to lose charge.
the bummer here is that one cannot have the key in the ignition in the accessory position with the door open. well, you can, but the non-stop dinging will compel you to either shut the door, or turn the ignition switch to "run" to make it stop.
something i really wish ford would consider. i sit in my truck all day and sometimes, i'd really like to just open the doors, kill the dome lights, and listen to the radio.
A - Off
B - Accessory
C - On
D - Start
jyarosz - I recently bought a 2013 F150 xlt.I'm trying to listen to the radio with the truck not running(nascar race).The key has to be on and the doors open so i can hear the speakers.After about 10 minutes the radio shuts off and the display says low battery.
Don't have one ?
Any ideas?
-click- the pic'
Goth 150
< This space intentionally -blank- >
