Sponsored by: Auxito
A few problems you may know a fix for.
Old Jun 14, 2014 | 02:38 PM
Thudpucker's Avatar
Thudpucker
Red face A few problems you may know a fix for.
1997/4.6/auto/4x4/lots of features.
Three questions:
1: Shift selector is loose, almost not positive. (where is that located)
2: Outside mirrors. Move-Right switch don't work. Left is OK.
3: Gauzy headlight covers! What do you do to get them clear again?
Old Jun 16, 2014 | 11:25 PM
Bluegrass 7's Avatar
Bluegrass 7
Get under the dash and look at the arm bolted to the shift tube. Is it loose?
On the mirrors, physically move them to the opposite side, (clicking will be heard) unless the movement is frozen..
Will the switch move them from that position back?
If yes, slow or some other action the switch is good and the mirror may need lubrication to free it up from age and dryness.
If no, the switch should be verified bad with a meter before replacing it.
On the head light covers, an auto parts store should have a restore kit. Follow directions and a little elbow grease and the covers will come clear unless they are 'crazed' with fine cracks.
This means you will use a rubbing compound to get to a new smooth surface before doing a polish job.
Good luck.
Old Jun 17, 2014 | 12:02 AM
Thudpucker's Avatar
Thudpucker
I'll come back soon with the results.
RailDawg
Jan 31, 2018 07:32 AM
93 mix 'n match
1997 - 2003 F150
Oct 10, 2011 12:07 AM
santacruzf250
Dec 14, 2009 03:57 PM
wfof250v10
Aug 28, 2008 08:20 PM
Strokin' Ace
Jun 29, 2005 05:39 AM
