302 Full length header help
Old Jun 13, 2014 | 11:15 PM
garthneddy's Avatar
garthneddy
I recently discovered a crack in the exhaust manifold of the 302 I swapped into my F250. Rather then replace the damaged piece with another manifold, I'm wanting to install some full length headers.
The problem I am going to have is in relation to the drivers side header exit location. I swapped my 2wd C6 with a ZF5 and an NP205 case, but since the 205 is much more compact then the original chain drive cases that came from the factory I'm anticipating some clearance issues. Im assuming the driveshaft will try to occupy the same location as the drivers side header collector.
Has anyone used the 302 headers designed for the 80-96 trucks after an NP205 swap? If anyone could get some measurments or pictures of the drivers side header exit that would be EXTREMELY helpful.
Old Jun 19, 2014 | 02:10 PM
garthneddy's Avatar
garthneddy
Nobody has full length headers on a 4x4 302 truck they can measure?
Branded
Ford Truck Parts for Sale
Mar 27, 2014 05:11 PM
Cody_302
Feb 6, 2011 09:52 PM
83FordPdx
Sep 11, 2008 01:06 PM
77effie
Feb 23, 2006 10:23 AM
David95Ford
Feb 17, 2005 10:53 AM
