holley 500
Old 06-14-2014, 09:16 PM
79ford matt's Avatar
79ford matt
79ford matt is offline
Pulled the 600 apart cleaned it up really good helped but im going to have to get some metering rods and jets for it. But hey I took it down the road and if I feather the gas it really comes to life. Once I get it all set ill pick up some new chevy rockers to help it even more love this site for all the info and the help everyone gets. Thanks all
Old 06-15-2014, 09:00 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
Is it giving a good, strong shot from the the accelerator nozzles? Did moving the linkage to the top hole in the pump arm make a difference? A bog or hesitation off idle is almost always a lean condition. The pump plunger went bad on my 500 and it had a bad stumble. Getting the pump shot right with the Offy C and its big, open plenum is crucial.
Do you have any source of heat for the bottom of the intake? It makes a big difference even during the summer down here in Texas.
Where is the base timing set? Vacuum advance hooked to ported or manifold vacuum source?
Old 06-15-2014, 12:10 PM
79ford matt
Getting a good shot from the pump forgot to move holes on the pump arm. I haven't finished the plate for heat just yet ill do that at work tomorrow. I don't know what the base timing is just used a vac gauge to set it. Vac advance is hooked to carb. didn't know weather to hook it to carb. or intake.
jwcopeland
18
01-26-2017 03:44 PM
Mutilator712
16
10-16-2016 08:46 PM
HighboyMac
11-10-2006 11:00 PM
mt_ford_300
02-24-2004 09:05 PM
DrFord
11-02-2001 11:42 PM
Quick Reply: holley 500
