Sponsored by: Real Truck
E450 w/7.3 - Alternator system issues
Old Jun 11, 2014 | 10:23 PM
gamber's Avatar
gamber
Greetings all,
I am a new member of the forums.
Recently, I purchased a 2000 E450 with a 7.3 Powerstroke as a rolling shop.
After I purchased it, I decided to give it a good clean, and DOH! sprayed out the interior with a pressure washer (I know better, just got caught up in the new rolling workshop). All was fine initially, now run into a couple of problems, may or not be related:
1. Alternator will not output any voltage
2. No warning indicators, signal or high beam indicators
Here are my details, forgive the long windiness, I just want to have as much detail available for troubleshooting.
Starting with the simpler, I hope of the two, here we go:
Warning Indicators
Indicators currently do not work, to best of my recollection:
  • airbag
  • battery
  • brake
  • abs
  • high beam
  • left signal
  • right signal
  • seatbelt?
If I recall correctly, service engine light does illuminate.
Engine coolant temp gauge does not work, believe to be unrelated, so changed sensor today.
Fuse #2 has been checked, showed continuity, but not changed out.
Alternator
As my voltage indicator illustrates a constant drain, I checked the alternator.
  • alternator + to ground showed battery voltage, indicating a alternator problem
  • replaced alternator, same as above
  • replaced alternator #2, same as above
Checks (multimeter)
  • continuity from alternator positive to bus bar, indicating that this wire is good
  • ASI - I to ground. Shows battery voltage both when key is on, and when key is off
At this stage, I assume that alternator is fine and that exciter wire (I) is the problem. As this wire, as I can tell, is series with the battery warning indicator light, which is currently not functioning therefore "no indicator light = no power to exciter".
Plans are to troubleshoot with the following steps:
  1. remove and replace fuse #2
  2. check for continuity between fuse box to panel
  3. ?
  4. ?
  5. directly wire exciter to battery to see if alternator will then generate voltage?
  6. ?
A few questions:
  1. Why does multimeter show battery voltage being the same to the exciter wire (I to battery/ground) regardless to whether key is in on or off position? Have I misread something here, as it does not make sense?
  2. Is there a separate connector for the warning indicator lights from the rest of the dash?
  3. How can I remove the fuse panel to fully examine/clean/etc?
  4. Assuming I may have a short due to my short sightedness, and as I have left a few steps blank, any suggestions on how to proceed?
  5. Should I move immediately to jumping (I) to ground so see if alternator will then generate voltage?
  6. When shall I admit defeat and take it to a shop?
Thanks in advance, there has been alot of head scratching and I need to get the rig up and rolling for a job early next week?
Old Jun 12, 2014 | 05:27 AM
senix's Avatar
senix
Welcome aboard, bump this to the top for you.
Knucklesmd
2004 - 2008 F150
Nov 14, 2015 09:30 PM
mck99f250
Jun 15, 2011 07:38 PM
r0n1n
Electrical Systems/Wiring
Jun 27, 2009 08:53 AM
adambird
Dec 10, 2008 08:42 PM
Ghostford
Oct 8, 2008 07:28 AM
