Nos part number help
Old Jun 10, 2014 | 04:25 PM
JayzDaddy's Avatar
JayzDaddy
I found a set of nos 16" to 15" hubcap reducers [trim rings] could you please tell me what year/ application this part # is for? e5ta1a090aa i am thinking its for a 80s truck?
thank you
Old Jun 10, 2014 | 06:27 PM
ctubutis's Avatar
ctubutis
I can't find such a thing in the 1980/89 Light Truck Master Parts Catalog, which can mean:
1) They were for sedans, in which case hope that ND Bill stops by, or
2) This truck parts catalog is incomplete (I know it's missing at least a few pages here and there)
Old Jun 10, 2014 | 06:41 PM
maytag906's Avatar
maytag906
IIRC, I had a 1980 F250 SCab (the light duty one) that used those. You could put 15" hubcaps on the 16.5 rims.
Old Jun 10, 2014 | 08:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Likely that is an engineering number, not a part number.
The AA suffix is a revision.
By the first four digits of the number it was originally designed for a 1985 truck.
Old Jun 10, 2014 | 09:13 PM
JayzDaddy's Avatar
JayzDaddy
Dunno if this will tell you more
Old Jun 10, 2014 | 09:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The number found on the part is an engineering number.
The number to order the part is different.
Bill (NumberDummy) could tell you.
My netbook has no optical drive to read my parts CD.
Old Jun 10, 2014 | 10:16 PM
ctubutis's Avatar
ctubutis
Right, it's an Engineering ID number and not a part number. But...
E5TA - the E5 means it was designed in 1985, the TA means it's a truck chassis part
If it were a Service (replacement) Part Number, the E5TA would be E5TZ, instead.)
The AA at the end is just the revision number
But the 1A090 is the Group number, and I'm not finding any mention of that in my catalog. Maybe Bill will stop by....
Old Jun 11, 2014 | 04:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ctubutis
It's an Engineering ID number and not a part number. But, E5TA - the E5 means it was designed in 1985, the TA means it's a truck chassis part.
If it were a Service (replacement) Part Number, the E5TA would be E5TZ instead.
The AA at the end is just the revision number.
But the 1A090 is the ID engineering basic number, and I'm not finding any mention of that in my catalog. You won't.
1A090 is the ID engineering basic number for 1210 trim ring.
I couldn't find a cross reference for E5TA-1A090-AA. It might be E5TZ-1210-A (see parts catalog applications).
It's not E3TZ-1210-C because I found its ID number, which is: E3TA-1A090-AA.
btw: You don't need trim rings to install hubcaps, but you do need them to install wheel covers. People tend confuse hubcaps with wheel covers, hubcaps only cover the center of the wheel.
1972/79 F250/350: In order to install D2AZ-1130-J 15" LTD wheel covers on 16" wheels, D2TZ-1210-A trim ring was snapped on first, then the 15" wheel cover was snapped onto the trim ring.
Old Jun 11, 2014 | 08:04 AM
Rogue_Wulff's Avatar
Rogue_Wulff
It was kind of odd seeing a F250/350 with full wheel covers at first. I was used to seeing those with nothing but the "dog dish" hub caps. Of course, that was in days when a person only bought a F250/350 because they actually *needed* that much truck, not because it was the "in" thing to do, or a status symbol........
Old Jun 11, 2014 | 04:30 PM
maytag906's Avatar
maytag906
Correct, Bill, wheel covers is what I had. They were the 15" LTD style.
Old Jun 11, 2014 | 05:05 PM
GLR's Avatar
GLR
I've got those "rings" on my 86 F250 SCab. Use the same 15" wheel covers.
bajoquinto10
1997 - 2003 F150
Feb 16, 2015 05:42 AM
ragens 87
Aug 26, 2014 09:38 AM
SteveVFX4
Mar 12, 2008 03:05 PM
