About that time to go to electric fuel
#46
haha!! right? Just call me an idiot.... Had too much going on at once... You might already know this, but you can turn the crank by hand and it should fall down into the oil pan, if it hasn't already...was talking to Bill and that was his input. Of course, that's only if you can't reach it with a magnet and still see it sitting on top of the cam lobe. Hope this helps!
#48
Oh no!! The plunger fell out? The best you could probably do with that small hole is use a small claw or a strong magnet. I hope you don't have to pull the intake.
The way my kit worked just required me to turn that fitting by the turbo clockwise until it was parallel with the head. It tightened it down a little more. I was then able to slide the line under the turbo and connect it. The only problem I had was me not tightening stuff down enough so when I primed the pump, it started leaking. I just had to tighten down three fittings until they quit leaking. So far, so good. Now that I have done this install, I think it's kinda crazy to have someone replace those fittings when it can be avoided...unless they are just thrashed. let us know what happens.
I think I was a lucky one, the plunger was still in the hole where its supposed to be being propped up still so the position of the motor helped me. All I did was pull on the plunger with vice grips and it came right out. I already put the freeze plug that came with the kit so moving on. It took me the whole day yesterday just for teardown. That d%$^ turbo is such a pain but I did pull it so I'll do the O-rings at the same time. Crappy part is I put aside my AC compressor to get behind it and the old hose sprung a leak so looks like I got more work and more $$$$$$
Can I get those O-rings at NAPA?
#49
#51
What he said...did a brain fart and didn't even think about that. You need them fast though don't you? Could have them overnighted I guess.
#52
#54
My computer must've not actually posted last night...
Long story short no. Not yet. Why? Cuz im too particular is the best excuse i can give. lol
After I got it from Bill I found out I have no room in between my t-case and front fuel tank on the inside of the frame rail to tap into the fuel lines before the selector valve.
That is when I decided I will get the 38 gallon rear and remove the front tank so I still have the same-ish capacity and will have room on that inner frame rail.
I know I could have either wrapped the fuel lines around to the outter side of the frame rail. Or routed them across to the passengers side frame rail....or put a hole in my bed and mounted them in the space between my tool box and cab.
So I guess picky. lol
And I still haven't decided...I liked being able to drive 6 1/2 hours to your place...then 6 or whatever to newport without having to fill up....
#55
I got the system installed. I sacrificed the AC line and the selector valve doing it. My twin fortunatly had a spare valve, those things are $380 from the stealership. Anyways my phone died early so I didnt get the final pic of the valley.
I havent driven it yet but Ive already notice this is the smoothest running OBS Ive heard in person, no fluctation in sound, just one monotone idle
Here's what came in the mail
The Fuel Bowl delete (one in 2 out) installed
Regulator
Trying to show the front passenger fitting behind the alternator
Front driver fitting
Back Driver Fitting and hardline
Back Passenger fitting next to down pipe
Filter and pump bracket between the transfer case and the front tank on the driver side of frame
Filters
This is what the other side of the bracket looks like
Regulator
Filters
#57
#59
#60
Hey did you ever look all your list of parts up and figure it out so I can start buying parts?? I have all the stuff for the repairs now. I think we can put the fittings in by the turbo for the efuel and put caps on them so we don't have to take it apart again to do the efuel.... We can discuss it later... Lemme know wen you are free to work...
