no heat - help
Old Jul 8, 2003 | 10:01 AM
rinkrat1999's Avatar
rinkrat1999
no heat - help
Inherited my Dad's 1989 F250 - problem is NO HEAT - replaced radiator (leaked), cleaned out heater core. Still no heat. Checked Chilton's repair manual at library - no help.
Anyone know about dismantling the heater to see if a door isn't working - if I have a vacuum leak or cable broken...HELP?
Old Jul 8, 2003 | 08:04 PM
Frdf150's Avatar
Frdf150
no heat - help
Check to see if your heat selector cold selector slide is hard to move from left to right. IE cold to hot . IF so you have a problem with the gate located up under glove box and dash area?
Old Jul 8, 2003 | 10:24 PM
Jimbo302's Avatar
Jimbo302
no heat - help
I have the same problem in my 95. Interested to hear some ideas.
Old Jul 9, 2003 | 02:15 PM
steve83's Avatar
steve83
no heat - help
Do you get ANY airflow? Have you put a water hose to the heater core to see if water can flow thru it? The temperature blend door is cable-operated on all '80-96 F-series, but they are known to come off their hinges & bind. The easiest way to check is to pull the evaporator cover and look thru the large hole in the firewall - it's right there.
Old Jul 9, 2003 | 06:47 PM
Jimbo302's Avatar
Jimbo302
no heat - help
Thanks for the info steve, here is my issue:
https://www.ford-trucks.com/forums/s...hreadid=132135
fordiesel69
Nov 10, 2013 07:49 AM
kajunkenny
Dec 25, 2010 02:04 AM
ford hunter
Nov 22, 2007 06:18 AM
tat2u61
Feb 8, 2006 05:58 AM
