302 vs 351 build
Nope. Nothing in the wiring. All you need to do is get a computer that matches your transmission and bolt it in. It will run on the 302 computer but just won't have its full potential.
SD= speed density
MAF= mass air flow
He was wondering if quarterhorse will work on a speed density computer, or if he would need to swap to mass air.
I believe quarterhorse works on sd. You would have to research the computer codes of what is compatible. You're limited more, but at least you would be able to tune it.
MAF= mass air flow
SD= speed density
MAF= mass air flow
MAF= mass air flow
You can use the quarterhorse with speed density provided that you find the correct strategy for that ECU. I don't think you will find much out there for support on the forums though.
You're overthinking this.
It's just slight changes in tuning. Like emissions and fuel trims.
They are all compatible with each other, as long as engine and trans combo is correct. So any sd 351 e4od computer can be interchanged with any other sd 351 e4od computer. Even though the strategy or ecu code is different.
Now it makes sense. I'm beginning to think about building a 302 since there's hardly and 351s in the area, and the ones I can find are way overpriced. I'm just worried about sacrificing bottom end. And I know it almost seems backwards to build something that doesn't have near the potential of the 351 but I don't want to wait forever to get going. I'm thinking I'm gonna go 302 if the price is right.
