The wanderer
Old Jun 6, 2014 | 06:53 PM
timmytim240's Avatar
timmytim240
The wanderer
I have this 81 f100 and it wonders all over the road. Much worse than the normal issue these trucks are known to do. There isn't any play in the steering wheel so I'm thinking its not the gear box. When I am on a gravel parking lot and turn in a circle the front end seems to slide like one wheel isn't tracking the same as the other. And any little bump or pot hole makes truck jump across road. Any ideas what this could be? Thanks
Old Jun 6, 2014 | 07:26 PM
bill06447's Avatar
bill06447
Toe-in (or out) is incorrect, assuming you gave everything underneath a shake or two ~Bill
Old Jun 6, 2014 | 09:30 PM
Franklin2's Avatar
Franklin2
Take it to a frontend shop and see what they say when they go to align it. They may say you need parts, and usually will charge you a small fee if you want to take it off the rack and go home and replace them yourself.
Old Jun 6, 2014 | 09:41 PM
Rogue_Wulff's Avatar
Rogue_Wulff
King pins or ball joints? 81 can be either.
If king pins, make sure they aren't trying to sieze up. Jack the front wheels off the ground, and attempt to grease them. If the grease won't go in, it may be time to service or replace them.
Old Jun 6, 2014 | 09:55 PM
timmytim240
Thanks guys
Old Jun 7, 2014 | 02:54 AM
bert cook's Avatar
bert cook
Thumbs up
I have an 81 f100 as well don't forget to check the radius arm bushings
Old Jun 7, 2014 | 07:28 AM
f100beatertruck's Avatar
f100beatertruck
And the pivot bushings.
octaneforce
Apr 17, 2013 04:16 PM
Green Streak
Jan 21, 2010 05:26 PM
jimstrecker
15
May 26, 2008 05:44 PM
wisconsin
19
Jan 22, 2008 10:40 AM
kidoo
Mar 18, 2007 06:36 PM
