1978 - 1996 Big Bronco
axle codes
Old Jul 7, 2003 | 11:50 PM
montster's Avatar
montster
axle codes
I have a 86 bronco with a axle code - H6
and my 83 bronco axle code is H8
can anyone tell me what the ratios for these are or where to find them
thanks
Old Jul 7, 2003 | 11:57 PM
andym's Avatar
andym
axle codes
H6 is a ford 9" 3.50:1 Limited Slip
H8 is a ford 8.8" 3.08:1 Limited Slip
Old Jul 8, 2003 | 12:13 AM
steve83's Avatar
steve83
axle codes
https://www.ford-trucks.com/articles/2003/9.php
Old Jul 8, 2003 | 08:01 AM
montster's Avatar
montster
axle codes
thanks alot. had a real hard time trying to find info, which of the two do you think whould be better to keep I have a I-6 300 and a manual 4 speed with a real low first( I can let the clutch out in first and it wont stall, just idles down the road)
Old Jul 8, 2003 | 10:08 PM
justshootme84's Avatar
justshootme84
axle codes
That's good for off-road, and so is the 9" with 3.50 gears. The 8.8" with 3.08 gears is more of a highway ratio, thus better mileage, unless you go to 31/32" tires and then it's under-powered. The 300 I-6 is a stump- pulling hoss!
Old Jul 8, 2003 | 10:45 PM
mrwizard's Avatar
mrwizard
axle codes
The axle code on my door sticker says H9B. I know the H9 part is 3.55 L/S, but what does the 'B' stand for? Maybe 'B'oth, as in front L/S too? The way my front diff behaves, I do suspect it is a L/S.
Old Jul 8, 2003 | 11:44 PM
andym's Avatar
andym
axle codes
I've never seen a three digit axle code before. I've never even HEARD of one.
There are a couple of ways to tell if you have an LS front axle.
One way is to crawl under and scrape the gunk off the tag. My D44 IFS says '3.54' on it, so I know it's open (3L54 would mean factory LS). Of course, if anyone installed an LS unit aftermarket, or swapped the carrier, this won't work.
The foolproof way is to jack up both front wheels and spin one by hand. If both wheels spin in the same direction, it's got LS. If the other wheel spins the opposite way, then it's open.
Factory LS units in the front are pretty tough to come by, from what I can tell. Count yourself lucky if you have one.
Old Jul 9, 2003 | 08:29 AM
DeGideo's Avatar
DeGideo
axle codes
It could be you have a front limited-slip,but according to 1990 Ford spec book,a front limited-slip axle code for Bronco,F-150,F-250,& F-350 would be a three digit code,but the third digit would be a '2'. A 'H92' code would be 3.55:1 front&rear limited-slip. Does your truck have auto hubs,or manual hubs? I don't know exactly what year Ford changed it, but you could only get the optional front limited-slip if you had standard locking hubs. Could that 'B' in your truck's three digit axle code be a '2'?
Old Jul 9, 2003 | 01:21 PM
steve83's Avatar
steve83
axle codes
I've never seen "B" as the 3rd digit. L/S in front is code "2" in the 3rd position.
Old Jul 9, 2003 | 02:24 PM
mrwizard's Avatar
mrwizard
axle codes
It's most definately a 'B'. Came standard with manual hubs. Just changed to Mile Markers because of some noise I was getting when hubs were locked. Didn't solve the problem, and I think now it's the slip joint in the front driveshaft that's dry and clunking around. Front end jacked up and hubs locked, both wheel turn the same direction. If only one tire is off the ground with both hubs locked, I can't spin the tire that's in the air. I can't see the tag on the axle because it was nicely undercoated by the used car dealer before I bought it. Here's a picture of the door sticker.
Old Jul 9, 2003 | 05:48 PM
steve83's Avatar
steve83
axle codes
My sticker code list is for '83, so I don't know what all those mean.
It's surprising that the total reserve capacity is less than the front axle's, and that it's only 99lb...
Old Jul 10, 2003 | 09:09 PM
Wakeboarder141's Avatar
Wakeboarder141
axle codes
If my axle code is an H9 I understand that is the 3.55 LS but is that the 9" or 8.8"?
Old Jul 10, 2003 | 11:11 PM
andym's Avatar
andym
axle codes
It's an 8.8" axle. Ford stopped making the 9" in the early 80's.
Old Jul 11, 2003 | 12:13 AM
Mil1ion's Avatar
Mil1ion
axle codes
The B is probably the power steering designate code.
Much Like the J was in the 70's.
I'll do some research and find out.
Old Jul 11, 2003 | 12:43 AM
mrwizard's Avatar
mrwizard
axle codes
Cool, thanks.
