2015 F350 platinum
#46
Received 5,368 Likes
on
#47
The advantage of the wide track is that the front wheels turn a full 45* where as the regular fronts only turn 38*. A huge difference in turning radius, but you can't turn the wide track to a lock position and the truck in 4wd. If you do, the knuckle or axle will break, which is pretty expensive.
#49
nice looking rig!
Hey Guys...I'm a newbie to this heavy towing and need some advice. I'm looking at a toy hauler about 17500 lbs. I was going to upgrade to a 15 diesel but not wild about getting a dually. Will a 2500 tow this much weight without any issues? Any advice will help.
don't mean to hijack thread.
That red does look awesome.
Thanks Guys
Thanks Guys
#50
Thanks Guys
Thanks Guys
that would right at the 350 SRW total carrying capacity. (RAWR 7100-3500 usually)
250 RAWR = 6100
no people, fuel, stuff, spare.
but you'll be over on the max trailer, 15900 CC 4x4
and over on the GCWR too 11300+17500 = 28800, max = 23500
2015 Ford Super Duty | View Towing Specifications | Ford.com
so, short answer, no a 250 will not be adequate, and a 350 SRW will not be either
#51
on
Thanks Guys
Thanks Guys
After working all the numbers I ended up spec'd out with the truck in my sig line.
F350 Crew Cab, Dually (long bed), 4x4, 6.7 PSD, fifth wheel prep and hitch.
I was not wild about a dually either, but with the weights we will be towing, I would rather have the added security and stability of the dual wheels.
This is for my retirement and we aim to have a good time - that doesn't include white knuckle driving..
#52
Copied from another Ford site:
Chassis improvements
The F-350 is available with a high-capacity towing package that includes new front springs and a wide track axle, increasing the gross combined weight rating with the 6.7-liter Power Stroke engine from 31,900 pounds to 35,000 pounds.
I got to try a 450 at a camp rally last week. what a difference just pulling out of the site.
NO, if you want that heavy of a trailer just start with a 350 DRW and consider the 450 (or 350 with the 450 axle)
Check with your insurance company too. My 350 DW put me into a commercial policy for 2 years.
Having a toy hauler you will find it extremely easy to exceed the GVW. Sometimes without any toys in the garage.
