Radiator
Old Jun 4, 2014 | 07:47 PM
maverick600's Avatar
maverick600
Go on ebay and search for a radiator to fit your truck.....you will see some aluminum ones forsale. I bought one for my 76 dent. It was bigger (longer) than my original one but there are bolts holes already drilled in your core support. All I did was get a 3/8 bolt and used a nut to make the bolt stationary and it also served as a spacer to keep it even with the pass side original bolt holes. It will specify a chevy conversion radiator which means the top hose is on the drivers side instead of the pass side like yours is. Juat get a flex hose or aeatch through their inventory to find one that fits and let it eat. I did not have a shroud nor did I have ac and it ran cooler than it ever did with the original radiator. The coat with ahipping was leas than 200 if I remember correctly and its a good quality. Matter of fact I bought one for my 71 and installed it today.
Old Jun 4, 2014 | 07:49 PM
maverick600
The maker is champion radiator. I had to go look cause I couldnt remember. If tou just give them a call they will help you get what you need and seem pretty knowledgeable as well.
FordStolz68
21
May 30, 2015 05:12 PM
azhoser
Arizona Chapter
Sep 5, 2013 10:21 PM
Dtmaster2008
May 29, 2013 11:49 PM
ragphoto
Mar 2, 2011 07:55 PM
mark460
Texas Chapter
Jun 12, 2005 08:25 PM
