2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
coolant change
Old May 31, 2014 | 09:52 PM
bunky383's Avatar
bunky383
coolant change
decided to change the coolant/change thermostat and rad cap in my '07 expy. drained the rad and pulled the block plug on the driver's side. couldn't locate the plug on the passenger side. perhaps it's behind the starter. anyways, block plug came out clean. it was a 6 or 8mm hex. put in about 12 liters or so. just thought i'd share.
Old Jun 2, 2014 | 09:04 PM
montecarlo31's Avatar
montecarlo31
Isn't the freeze plug replaced with the coolant heater on the northern models?
Old Jun 2, 2014 | 09:13 PM
bunky383's Avatar
bunky383
Negative Monte, there is a threaded plug below the block heater/frost plug on the drivers side.
Sent from my Z10 using IB AutoGroup
Old Jun 2, 2014 | 10:05 PM
montecarlo31
humm weird, my truck did not ship from the factory and thus the ford part required removal of a freeze plug for installation. Weird.
Old Jun 2, 2014 | 10:20 PM
bunky383's Avatar
bunky383
Sorry, I misunderstood you. Yes the block heater takes the place of the frost plug in the rear most spot. What I pulled out to drain the coolant was a threaded plug below the block heater.
dvcroket
Jul 5, 2018 07:42 AM
fyrehose
Aug 20, 2014 11:55 PM
robjs111
Sep 10, 2010 01:21 AM
powerstroke6ltr
Jan 31, 2006 01:56 PM
84whitef250
Apr 27, 2004 04:57 PM
