1986 F250 4x4 components on F150 frame
Old 05-31-2014, 08:44 PM
GLR's Avatar
GLR
GLR is offline
Couldn't find the answer on searching. Have a 86 F250 4x4 351, C-6, single cab, 8' bed. The cab is shot, bed gone. Picked up a 86 F150 2wd cab, 8'bed, was 302 EFI. Engine, trans, front clip are gone. I have to swap a couple of cross members anyway so I was wondering if the basic frame/rails would be the same. The F150 is a NC vehicle and the frame is mint compared to the F250 frame. I know spring hangers/ perches etc would have to be swapped.
Thanks for any input.
Old 05-31-2014, 09:01 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Cross members are the same
Old 05-31-2014, 10:02 PM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
From what I understand the F250 frames are thicker and the front of them is a bit different. If you have the D44 version of the TTB why not run the coil spring F150 setup and convert to 8-lugs with some GM parts. There's a sticky in the How-To section I believe. You'd have to get the F250 4x4 beams but that's not that hard. I'm just outside Philly and if you can't find the beams I have a set. I don't really want to let them go, but I would to a FTE member to aid a project.
EDIT: Ok, it was on FSB... Dana 44 8 lug swap with pictures
Old 06-01-2014, 09:40 AM
GLR's Avatar
GLR
GLR is offline
I've got the F250 4x4 on the rusty frame. The frame I was thinking about using is a F150 frame 2wd. If the front of the frame is different between 2 and 4 wd, I guess it won't work easily. Have to start taking measurements. Was hoping it might just be a matter of changing cross members.
Old 06-01-2014, 11:54 AM
f100beatertruck
I don't think they're too different, but I'm not sure. I think the 2wd Fx50 trucks are all the same basically and there are plenty of guys that do leaf conversions on 2wd F250/350's. From what I understand the F150 4x4 TTB axle stuff bolts right up.
https://www.ford-trucks.com/forums/1...le-donors.html
https://www.ford-trucks.com/forums/5...onversion.html
Old 06-02-2014, 04:40 AM
Diesel_Brad
There are quite a few differences between a 2wd F150 frame and a 4wd F250 frame...
2wd F150
3/16"
2.5" rear leaf springs
coil spring front end
4wd F250
1/4"
3" rear leaf springs
leaf spring front end
Old 06-02-2014, 07:19 AM
GLR's Avatar
GLR
GLR is offline
Thanks Brad. Parts of the F250 frame are about 1/8" thick. I have enough good parts to convert the back end to 3" springs. Wasn't sure about the front though. All these years and never got around to playing with 4x4's.
4x484150
Ford Truck Parts for Sale
07-31-2015 02:26 PM
harrysnyder
04-14-2011 05:41 AM
dyoungen
05-03-2010 10:40 PM
derherr65
08-16-2006 05:17 PM
Quick Reply: 1986 F250 4x4 components on F150 frame
