Where is the Glow Plug Control Module located on a 2007 f250 6.0? I am getting P063 as the only code throwing with a check engine light on. I see many saying to check the connector and wiring before just buying a new one. Advice and where it's located with pic appreciated.
Thanks
Is replacing this just a plug and play kind of thing? Can you just unplug and remove the old one and put the new one on and plug in? No programming or anything else to do?
Start with the gpcm plug and play and a lot cheaper than a PCM [about a grand]
The PCM may need to be FLASHED updated depending if your still stock; been flashed before or running a tuner and a tune.
It is very easy to change - plug and play. Likely will want to remove the CAC hose/pipe to make life easier. That's the only work really. I am not sure about the code. P0673 is most likely the #3 glow plug (second from the front passenger's side). Is this the code or P0683?
DY-876 is the Motorcraft part number for an OEM replacement GPCM. Do a search on that to determine where you can obtain one for the best price. In answer to your question, it is just plug and play, and most likely the source of your problem.
Under $100 is a good deal I assume. Local stealer here in San Antonio wants $185.00 for it. I have a message into Tousley to see what they can do. Would like to find one under $100 locally but oh well. I would love for the CEL to go dark again.
