Engine mount towers ?
Old Jul 7, 2003 | 03:27 PM
St_alfonzospancakebreakfa's Avatar
Question Engine mount towers ?
Hello! Does anyone know if the engine mount towers for 351M are the same as 351W in a 73-79 F100? I'm not positive but I'm thinking the blocks were the same but the M had longer stroke, on the other hand it may be a modified clevland ???? Just don't know???
Old Jul 7, 2003 | 03:37 PM
Well I just realized (with some help from my ford book) that a 351M is a modified cleveland but still don't know if the mount towers are interchangable ???? The reason I ask is sometime over the upcoming winter I'm going to rebuild a '69 351w I picked up and I'd like to put it in my '79 F100 which currently has a 300 L6. I know the 300 mount towers won't work so my search for proper mount towers is on, any help greatly appreciated! Thanks
Old Jul 8, 2003 | 12:30 AM
ludis's Avatar
ludis
You should have no trouble finding frame mount brackets. You should be able to use brackets for a 302 or a 351W, both of which are common. Also, I'd bet that the brackets for a 351M and 400 are the same.
Note that the 351W is just a tall deck 302. And the 351M/400 are almost just tall deck 351C's. And finally, the 351C/351M/400 are just reworked 302/351W's - heads from one will bolt to the other, although a cooling passage won't line up properly.
Old Jul 8, 2003 | 04:34 PM
Kemicalburns's Avatar
Kemicalburns
first off , is this truck 4x4. if so then your gonna need someone to fab up a pair. that motor was never offered in a 4x4 from those years . and yes the blocks are different. I went this route a couple of years back because i wanted a 351w in my 73 highboy. now you can use 300-6 mount towers, cut them half way down from the top and then weld a plate that runs about 3-4 inches back. or try and drill different holes in the frame to bolt the towers on. im sure it can be done but at 16 i didnt have the funds to get somthing fabbed up .
good luck
later
Old Jul 9, 2003 | 01:25 AM
ludis's Avatar
ludis
Mounting bracket part numbers for 73-79 F-series:
6028 RH frame bracket
6029 LH frame bracket
6030 RH block bracket
6031 LH block bracket
FE 2WD: D4TZ-6028-B & D4TZ-6029-B
FE 4WD exc/Crewcab: C6TZ-6028-D & C6TZ-6029-F
FE 4WD Crewcab: D3TZ-6028-C & D3TZ-6029-B
302 2WD: D7TZ-6028-B & D7TZ-6029-B
302 4WD: not offerred
351W 2WD: not offerred
351W 4WD: not offerred
351M/400 2WD: D7TZ-6028-B & D7TZ-6029-B
351M/400 4WD: D8TZ-6028-C & D8TZ-6029-D or
D7TZ-6028-D & D8TZ-6029-A
460 2WD: D3TZ-6028-A, D3TZ-6029-A, D3TZ-6030-A, D3TZ-6031-A
460 4WD: not offerred
Old Jul 12, 2003 | 03:20 PM
Wow ! Thanks for all the p/n's, will be a big help !
Old Jul 12, 2003 | 03:22 PM
By the way my 79 F100 is a 2 wheel drive. Thx
Old Jul 13, 2003 | 12:38 AM
ludis's Avatar
ludis
BTW, those are "service numbers". They are what you'd ask for at the Ford parts counter. They are not the numbers that appear on the parts themselves.
Rasputin53
May 2, 2017 10:28 AM
winginit
Jun 21, 2016 12:18 AM
1979 300i6
Dec 29, 2015 04:36 PM
cletusclark
Sep 20, 2011 09:36 PM
Blackfoot Big Block
13
Dec 8, 2009 09:27 PM
