94 f150 driveability problem
Old May 27, 2014 | 11:49 PM
btypd's Avatar
btypd
I have a 94 F150 351, 4x4, E4od with 210,000 miles on it. I have been working on it for awhile now (replacing bad sensors, full tune up and so on) as I get the time and funds to do so. Now the engine starts and idles fairly well (still need an IAC valve) but as soon as I bring it off idle and try to hold a steady rpm it fluctuates about 500-600 rpms. With the MAP sensor vacuum line off and plugged the engine will hold its rpms just fine. If I apply 19 pounds of vacuum to the MAP sensor with a manual pump and rpms held at about 1500 the engine seems to flood out and die. I've replaced the MAP sensor twice now thinking maybe the first one I bought was bad to no avail. Whatever is causing this doesn't flag any codes in the computer (which has also been replaced). Any advice would be greatly appreciated.
Jmanb13
Sep 19, 2015 07:48 PM
Flatbed
Feb 2, 2015 05:07 PM
BlackRyanf250
Electrical Systems/Wiring
Oct 30, 2013 05:11 PM
oldmansimek
Jan 15, 2010 04:53 PM
Donald Rohret
General Automotive Discussion
Jun 5, 2004 09:42 PM
