84 F150 Stepside
Old Jul 7, 2003 | 10:55 AM
mmcrorey's Avatar
mmcrorey
84 F150 Stepside
Hi all. I have been looking around the web to see other photos of 1984 F150 Stepsides. My father gave me his ranch truck this weekend and I really want to fix it up. Here is what we have done so far:
changed the engine from the straight 6 to a 351 v8.
changed the granny shifter to an automatic
added dual exhausts
added RV Cam
for some reason, the catalytic converters were not put on, so I do believe I will be needing to put these on to make it legal.
I am wanting to raise it up about 6 inches and put some 30" tires under it and restore the body. There are only a couple of dings on the body so that should not be that hard. I also want to change the bench seat to bucketseats.
I will continue to read other people's posts for ideas, but if someone knows of any pics out there on the web of this truck model and maybe some customized ones, I would really appreciate the help.
Thanks.
Old Jul 7, 2003 | 11:20 AM
steve83's Avatar
steve83
84 F150 Stepside
You don't need ANY lift for 30" tires (that's just stock size); certainly not 6"! You can run 33s on a 4WD F-150 with no lift and only the slightest adjustment to the bumper.\
30" tires under a 6" lift would look wierd.
Old Jul 7, 2003 | 11:55 AM
mmcrorey's Avatar
mmcrorey
84 F150 Stepside
Thanks for the info!
Quick question will it matter that it is only a 2wd¿
Old Jul 7, 2003 | 12:27 PM
steve83's Avatar
steve83
84 F150 Stepside
The 2WD suspension sits a little lower (especially in front), so you probably can't go straight to 33s without some "adjustments".
Try picking up a spare rim in a junkyard and shop the used tires stores for a decent 32 and test it.
Old Jul 7, 2003 | 12:32 PM
mmcrorey's Avatar
mmcrorey
84 F150 Stepside
Thanks again!
Old Jul 7, 2003 | 10:08 PM
mmcrorey's Avatar
mmcrorey
84 F150 Stepside
Another thing...currently, my dual exhaust does NOT have catalyic converters. Do I need to have them on there? Does the year model of the vehicle matter or is it the year of the engine that denotes requirement of the Catalytic Converters.
Old Jul 7, 2003 | 11:19 PM
steve83's Avatar
steve83
84 F150 Stepside
Check with your local vehicle inspection station or state police. Those laws vary by locale. Decent cats don't affect performance or reliability - only emissions.
Old Jul 9, 2003 | 11:29 AM
jrocco's Avatar
jrocco
84 F150 Stepside
If you have smog testing in your area then you will need the Cats to pass.
I bought Catco's from Summit and they worked great.
See my gallery it's an 80 but the same body style.
Old Jul 9, 2003 | 11:41 AM
mmcrorey's Avatar
mmcrorey
84 F150 Stepside
jrocco,
love the truck...it would be great to see my truck looking that clean. I can't wait to replace the wood bed either...it looks like **** right now.
I will look for the Catco's at Summit.
Old Jul 9, 2003 | 12:15 PM
jrocco's Avatar
jrocco
84 F150 Stepside
Thanks for the comments Mike
They are much appreciated.
fordman75
Projects
509
Apr 29, 2020 07:53 AM
austinfa83
Aug 17, 2013 10:20 AM
Tha_Stepside
28
Jun 13, 2008 12:18 AM
nwoparamedics
28
Nov 13, 2004 07:47 AM
