Ok I have a 99 f150 lariat 5.4 4x4 i drove it into my yard and turned it off and its never started again. It turns over fine just wont start I have replaced the fuel pump it was noisey anyway switched fuel pump relay its working i checked for fire and have fire at plugs 40 psi fuel pressure finally gave up and took it to my ford dealer they said ecm was bad so I brought back home an pulled my ecm seny out for repair got it back with a note no problem with unit reinstalled it still no start went back to ford they said ecm due to no groung to any injectors I have cleaned all the grounds also checked my key it is rejestering also replaced the reset switch for fuel pump any help. Thanks
first and foremost when you turn the key to the on position are all your electrics working, if so is the CEL on? if yes what codes is it giving? second when you turn your key all the way to the crank position does it attempt to crank, click, or grunt and then stop?
have you tried testing the connections to your injectors to ensure proper power is reaching them? also maybe try replacing the injectors just to verify that they arent bad themselves
No its not blinking I also have a plain key no chip for unlocking the doors if I put that in it blinks if I go back to my good key it comes on and goes off
That should rule out pats
Do you have a check engine light with key on engine off?
Maybe do a search on this forum for "coil drivers"
Good luck keep us posted
