Ignition Problems..... DuraSpark II
Old May 23, 2014 | 09:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm glad to hear you have the car running!
Sorry that I didn't mention that the pickup can go bad.
Usually it is the module that fails.
When testing across the orange and purple wires at the distributor plug you should find between 400 and 900 ohms.
Old May 23, 2014 | 10:06 PM
DoubleAr0n's Avatar
DoubleAr0n
It's all good. I'm just excited that I got it running. Now I just have to finish fabricating and welding up my exhaust and put fluid in the trans, might even get it on the road this weekend. I was certain I had it wired correctly. I have lost sleep going over and rewiring it in my head.
Old May 24, 2014 | 12:42 PM
KBinCO's Avatar
KBinCO
Ignition turned off, engine still running
Hey all I'm new to the forum, trying to figure out how everything works. Thought I would reply in here and see how it goes.
I have a 1985 Ford F-350, 460, Automatic
Original problem= Turned key and got absolutely nothing.
In succession I replaced battery, starter, solenoid, ignition switch, fuse and finally ran a new power wire from the solenoid to the ignition switch.
Truck starts!.....but now it won't stop when you turn the ignition off!
I'm thinking it's the relay switch. Any other suggestions outside of that?????
Old May 24, 2014 | 02:03 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It won't stop cranking over, or you can't shut the ignition off?
Old May 24, 2014 | 03:02 PM
KBinCO's Avatar
KBinCO
The truck starts fine. The ignition turns back normally. I can even take the key out of the ignition. But the engine remains running as if I didn't turn the ignition off at all.
Old May 24, 2014 | 03:53 PM
JimsRebel's Avatar
JimsRebel
Do you have a tilt wheel?
Old May 24, 2014 | 04:34 PM
KBinCO's Avatar
KBinCO
No just standard
Old May 24, 2014 | 04:59 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do the accessories turn off with the key?
We are asking to see if it is a broken actuator rod or if the ignition is backfeeding from the alternator.
Old May 24, 2014 | 05:07 PM
KBinCO's Avatar
KBinCO
No, nothing turns off. The truck just stays running as normal. Like I said earlier I'm thinking it's the relay switch. Doesn't the relay switch tell the engine block to turn off? I've also read some things about a bad diode at the alternator?? Does that sound plausible?
Old May 24, 2014 | 05:46 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If the starter kept cranking it would be the relay.
If only the engine didn't shut off, it could be the alternator/ignition.
If all the accessories stay on it is most likely the ignition switch on the column.
Either your switch is suddenly WAY out of adjustment or the ignition actuator is broken.
This is much more common with tilt wheel columns, but not unheard of in a regular steering assembly.
Get down under the dash and find the ignition switch screwed to the top of the steering column.
See if you can reach above it and pull the rod back to the off position.
Remember Accy. is beyond off and lock.
Old May 24, 2014 | 06:24 PM
KBinCO's Avatar
KBinCO
I installed a new ignition switch already. Even if the truck starts normally, the rod can still have been broken?
Old May 24, 2014 | 06:54 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The pot metal rod pushes to the crank position.
If it is broken it cannot pull the switch into the off position.
Old May 24, 2014 | 06:55 PM
  #28
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If you installed a new switch, maybe you just did not adjust it correctly???
Old Jun 2, 2014 | 10:22 AM
  #29
another ford guy's Avatar
another ford guy
I put in the Duraspark II in last weekend after swapping the solenoid with one with the "I" terminal it stays running but really rough. i could not find a smooth idle within range of the distributor adjustment going to look for vacuum leaks this weekend and confirm TDC. I could not find a harness so i ordered the painless harness with an addin ceramic ballast resistor (DuraSpark II Ignition HarnessDetails | Painless Performance)
watt476
Apr 26, 2026 05:16 PM
ROKRAWL
Dec 30, 2012 09:32 PM
cyris426
Nov 22, 2012 09:10 AM
dcraig1000
Apr 17, 2012 05:53 AM
ihateminimumwage
Electrical Systems/Wiring
Jun 16, 2008 05:36 PM
