In a Bind and Need EGT Help
Old May 22, 2014 | 07:45 PM
Fargus's Avatar
Fargus
I know, heck of a first post, but I need help and hope you folks can provide it. I searched as best as possible and realized it will take a month of Sundays to find the answers I need.
My EGT sensors went out on the way to get my daughter. The 2 codes(p200c, p200e) said that the sensors in "Bank 1" are the culprit. I had a buddy take me to the ford house, got 2 shiny new sensors and now I have no clue where to put them. I found 3 sensors in the pipe and have no clue where "Bank 1" is located. The Ford house said there were 4. 2 in each bank.
The kicker is that I am suppose to be hauling the fifth wheel out of town in the morning hence the bind.
Old May 22, 2014 | 08:40 PM
Iowa Ford's Avatar
Iowa Ford
Fargus, sorry to hear of your problem.
The EGT sensors are in the exhaust system and there are 4 of them plus one NOX. sensor.
You can find all of this by looking at the top of the page where you originally posted this. It says Tech folder on it I think.
I am not an expert, but this is where I would look if I was in your situation.
Good luck.
Old May 22, 2014 | 08:51 PM
rtazz17's Avatar
rtazz17
Yeah there are some photos in threads somewhere on here as well if you dont find it in tech folder.
Old May 22, 2014 | 09:07 PM
Iowa Ford's Avatar
Iowa Ford
Ok so I went to the tech folder. first item says Diesel overview.
Downloaded it and went to Pg.79 or 81 of 94 of pdf.
And voila there it was the physical location of the Exhaust sensors !!!
Easy as can be .
Hope this helps some one. If not at least I had fun looking thru it.
Wrighton's Avatar
Wrighton
Read this thread its has diagram of the location for the 4 EGT Sensors. I have it printed out a copy and placed it in my glove box along with 2 new sensors, 13MM Flare Wrench. Hope the hell a failed Sensor doesn't leave me on the road while Towing my 5th wheel. I will be ready it this does occur.
https://www.ford-trucks.com/forums/1...-failures.html
Old May 23, 2014 | 06:43 AM
senix's Avatar
senix
Just to piggy back on this. It is almost EGT14 the one behind the dpf that gives the trouble.
Also the cab and chassis is now the same. for 2013 and beyond.
Old May 23, 2014 | 07:35 AM
WildWildWest's Avatar
WildWildWest
Code shows 12 or 13 to be the culprit.
Old May 23, 2014 | 07:37 AM
WildWildWest
That would suggest the two in the middle in the diagram below. It's probably only one that is the problem but since you have two sensors and it takes time to figure out which is bad u would just do both.
Old May 24, 2014 | 08:34 PM
Wrighton's Avatar
Wrighton
Crawled under the truck today and located all 4 EGT Sensors and removed each sensor and applied high temp anti seize to the threads. At 16,000 they were easy to remove. I'm prepared in case any of one of them bad boys fail. I bought my truck primarily for towing my boat or 5th wheel and the stories of failed sensors with stop safely now messages 50 - 100 miles from the nearest Ford dealer waiting for a tow isn't a good thing.
Old May 24, 2014 | 08:51 PM
vloney's Avatar
vloney
this help?
<form id="form1" method="post" action="Default.aspx?bookcode=TSB14-0108&market=US&language=EN&VIN=no">
<input id="__VIEWSTATE" name="__VIEWSTATE" value="/wEPDwULLTEwMjExMzU2MDVkZODEBQtQsJOBdQDIhY5y75rpi35 Y" type="hidden">
<?xml version="1.0" encoding="utf-8"?><style type="text/css"> BODY {margin-top:2%;margin-right:2%;margin-left:2%;font-family:arial;font-size:10pt} TH {font-size:10pt;font-family:arial} TH.bottomborder {font-size:10pt;font-family:arial;border-bottom: 1px solid gray} TD {font-size:10pt;font-family:arial;vertical-align:top} TD.noborder {border-bottom:none;border-top:none;font-size:10pt;font-family:arial;vertical-align:top} P {font-size:10pt;font-family:arial;margin-bottom:.4em;margin-top:.4em;} P.disclaimer {font-size:8pt;font-family:arial;margin-bottom:.2em;margin-top:.4em;} P.copyright {font-sizept;font-family:arial;margin-bottom:.2em;margin-top:.4em;} H2 {font-size:12pt;font-family:arial;margin-bottom:.2em} H3 {font-size:11pt;font-family:arial;margin-bottom:.2em} B {font-size:10pt;font-family:arial} I {font-size:10pt;font-family:arial} LI {font-size:10pt;font-family:arial;margin-left:-1em;margin-bottom:.4em;margin-top:.4em;} UL {font-size:10pt;font-family:arial;margin-bottom:0em;margin-top:0em} DIV.big {font-size:12pt;font-weight:bold;font-family:arial} TD.smallblue {font-size:7pt;background-color:#0000FF} A.small {font-size:8pt;font-family:arial;text-align:center} A.button {color:blue;background-color:#ccc;font-family:arial;font-size:12pt;cursor: poiner;border-style:solid;border-color:black;border-width:thin;text-decoration: none} </style><table border="3" cellSpacing="0" cellPadding="3" width="96%"><tbody><tr><td bgColor="#0000ff" colSpan="2">[************]Printable View[/COLOR] </td></tr><tr><td bgColor="#ffffff" width="25%" align="center">TSB 14-0108
</td><td bgColor="#ffffff" width="65%" align="left">6.7L DIESEL - DTCS P2080, P0544, P2084, P2031, P242A, P242B, P246E, P246F, P200C AND/OR P200E - BUILT ON OR BEFORE 12/15/2013
</td></tr><tr><td bgColor="#0000ff" colSpan="2">[************]Publication Date: May 22, 2014 [/COLOR]</td></tr></tbody></table>
<table border="0" width="100%"><tbody><tr><td width="7%">FORD: </td><td>2013-2014 F-Super Duty
</td></tr></tbody></table>ISSUE:
Some 2013-2014 F-Super Duty vehicles equipped with a 6.7L engine and built on or before 12/15/2013 may exhibit an illuminated malfunction indicator light (MIL) with exhaust gas temperature (EGT) sensor DTC stored in powertrain control module (PCM) memory. This may be caused by an improper crimp on the body side harness sensor connector. An improper sensor harness crimp can result in high EGT resistance and DTC P2080, P0544, P2084, P2031, P242A, P242B, P246E, P246F, P200C and/or P200E. ACTION:
Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE
  1. Using the Ford Integrated Diagnostic System (IDS) or equivalent, check for continuous memory diagnostic trouble codes (CMDTC).
  1. Is CMDTC P2080, P0544, P2084, P2031, P242A, P242B, P246E, P246F, P200C and/or P200E present?
    1. No - this procedure does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
    1. Yes - replace the 2-pin male connector on the vehicle body harness that corresponds with the EGT DTC observed using the solder splicing method. Refer to Wiring Diagram, Section 27-1 for EGT sensor locations. Refer to Wiring Diagram, Section 5-1 for solder splicing method instructions.
      1. Removing the EGT sensor from the vehicle is not required during the repair.
  1. Clear the DTC.
<table border="1" cellSpacing="0" cellPadding="3"><thead><tr><th class="bottomborder">PART NUMBER</th><th class="bottomborder">PART NAME</th></tr></thead><tbody><tr><td class="noborder">3U2Z-14S411-BXAB </td><td class="noborder">Pigtail Connector </td></tr></tbody></table>
<table border="1" cellSpacing="0" cellPadding="3"><tbody><tr><th class="bottomborder">OPERATION</th><th class="bottomborder">DESCRIPTION</th><th class="bottomborder">TIME</th></tr><tr><td class="noborder">140108A</td><td class="noborder">2013-2014 F-Super Duty 6.7L: Retrieve DTCs And Replace One (1) Male EGT Connector (Do Not Use With Any Other Labor Operations)</td><td class="noborder">0.5 Hr.</td></tr><tr><td class="noborder">140108B</td><td class="noborder">2013-2014 F-Super Duty 6.7L: Retrieve DTCs And Replace Two (2) Male EGT Connectors (Do Not Use With Any Other Labor Operations)</td><td class="noborder">0.7 Hr.</td></tr><tr><td class="noborder">140108C</td><td class="noborder">2013-2014 F-Super Duty 6.7L: Retrieve DTCs And Replace Three (3) Male EGT Connectors (Do Not Use With Any Other Labor Operations)</td><td class="noborder">0.9 Hr.</td></tr><tr><td class="noborder">14010</td><td class="noborder">2013-2014 F-Super Duty 6.7L: Retrieve DTCs And Replace All Four (4) Male EGT Connectors (Do Not Use With Any Other Labor Operations)</td><td class="noborder">1.1 Hrs.</td></tr></tbody></table>
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
<table border="1" cellSpacing="0" cellPadding="3"><tbody><tr><th class="bottomborder">BASIC PART NO.</th><th class="bottomborder">CONDITION CODE</th></tr><tr><td class="noborder">5J213 </td><td class="noborder">42 </td></tr></tbody></table>
<hr>NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2014 Ford Motor Company
</form>
Old May 24, 2014 | 09:12 PM
Wrighton's Avatar
Wrighton
Good info, now I need to carry a soldering iron as we'll. Why doesn't Ford have a recall and change the programming so the 2011-2015 6.7 has a speed limiter instead of pull over safely now! Thanks for the tech info.
Old May 24, 2014 | 09:23 PM
vloney's Avatar
vloney
So if a sensor says 1600 degrees and the rest of them show 300 (whether or not its right) you'll keep driving even if theres a fire. Then if someone dies in the fire, you're not going to sue Ford?
Old May 24, 2014 | 09:38 PM
wtrlogd's Avatar
wtrlogd
If the truck shuts itself off in -40 degree temps, in the middle of nowhere, it may end up finding itself on fire anyway.
Old May 25, 2014 | 06:51 AM
senix's Avatar
senix
If that is your issue, once replaced that won't ever be an issue again. It may have happened in transport.
Old May 25, 2014 | 07:00 AM
sdetweil's Avatar
sdetweil
They appear to be getting corrosion in the body side connector that wasn't experienced in testing.. the corrosion is affecting the sensor signal.
