Coolant smell
Old May 19, 2014 | 06:51 AM
Walwal44's Avatar
Walwal44
Coolant smell
Well this morning i was parked and all of a sudden my 2005 f150 5.4l started idling hard and then a coolant sent started coming through the air vents so i shut the truck off and havent started it since. This has never happened before so i have no clue what is wrong if anyone can help me it would be great!
Old May 19, 2014 | 10:38 PM
1saxman's Avatar
1saxman
Usually coolant smell inside is heater core leaking. Since it started running rough at the same time*, maybe you have a coolant leak under the hood. Have you looked for it???
* I don't know how this would be related to a coolant leak except maybe it was running hot and you didn't notice.
Old May 20, 2014 | 07:56 AM
jr105's Avatar
jr105
1saxman is right about the smell in the cab usually coming from a heater core, however the smell can be drawn in through the vent from outside if the blower is running.
Like he said, you need to look around and find the source. Any puddles under the truck? Rough idle could be something electrical getting wet under the hood.
Old May 20, 2014 | 08:16 AM
Walwal44's Avatar
Walwal44
I couldnt find any leaks and there were no puddles but i only took a quick look because i had to get into work but i will need to take a closer look when i get time the truck is parked for now im driving my 95 obs in the mean time.
jesse24spd
Feb 3, 2014 09:06 PM
lynch3763
1983 - 2012 Ranger & B-Series
Feb 15, 2011 02:52 PM
FordTruckGirl77
Dec 17, 2008 10:46 PM
zgiannijonesz
1997 - 2003 F150
Oct 30, 2007 08:43 PM
wlihntr
Feb 14, 2004 05:06 PM
