Rear window stickers
Old Jul 6, 2003 | 11:06 PM
1994ford's Avatar
1994ford
I want to put a large blue oval in my back window but it is a sliding one and im unsure of how to go about installing one of these. I would appreciate any help.
Old Jul 6, 2003 | 11:20 PM
Mil1ion's Avatar
Mil1ion
Slit the decal in the middle.
Old Jul 7, 2003 | 09:16 AM
1994ford's Avatar
1994ford
Yeah but there are the two pieces of window moulding that are raised a bit too. thats where i get confused on whats going on with it.
Old Jul 7, 2003 | 10:30 PM
fishmanndotcom's Avatar
fishmanndotcom
ok...put the sticker on with your window closed and all and it looks good, then cut with a razor where the window opens and where the moulding is
or put the sticker on the window with backing still on by using scotch tape and mark on the sticker where you think it should be cut at.
get creative man! It's not like you can't get another sticker and try it again.
-Jason-
Old Jul 8, 2003 | 12:23 AM
Mil1ion's Avatar
Mil1ion
Okay Specifically then !
Place the decal in the position you want it to be at.
Takea pencil and draw a line across the top portion of the decal where is cover the window trim.
No do the same for the bottom.
Cut the decal exactly in half.
Peel back the paper & Carefully place the top portion of the left or right side in Line with the pencil mark
Now the other side.
Or just do it like Jason & I said in our earlier posts
Attach > Slit down the middle.
Old Jul 10, 2003 | 09:59 AM
CobraXP's Avatar
CobraXP
From experience -
Put the entire sticker on intact first. Then cut the spaces where the window will be opening. Your sticker will look 10 times better. If you cut it first, you have to align the halves to make it look correct, which doesn't sound hard, but a flimsy sticker you are trying to align - it adds a couple levels of difficulty to the project.
