Do i have a 292?
Old Jul 14, 2003 | 04:25 PM
Midnite Cruiser's Avatar
Midnite Cruiser
Do i have a 292?
#1 is on the pass side , ie RF . Leave that dist in and you ll find #1 on the cap falls at about 12 o clock in realtion to the block (facing from firewall to rad.
Old Jul 15, 2003 | 09:20 AM
phjbbu's Avatar
phjbbu
Do i have a 292?
If you've found #1 cyl. on the dist. cap, great...now, all you'll need to do is to take the dist. cap off and have someone bump the starter so you know which direction the rotor rotates in. The next cylinder in the firing order would correspond to the next distributor cap post in the direction of travel of the rotor and the rest of the ignition wire locations for a given cylinder would be in the order as listed on the intake manifold.
Old Jul 15, 2003 | 10:34 AM
286merc's Avatar
286merc
Do i have a 292?
One thing yet to be established is if it is a 292 or 332 style engine.
They look a lot alike. How about giving the part # that is on the intake? It will be a 3 letter or letter/number combo followed by 4 numbers.
And YES, the 332 has the valve covers held on by 2 nuts, just like the 292.
The distributor runs CCW in both and have the same 1-5-4-8-6-3-7-2 firing order.
The cylinders are 1 to 4 on the passenger side, front to back and 5 to 8 on the drivers side on both.
Old Jul 15, 2003 | 12:02 PM
superbee's Avatar
superbee
Do i have a 292?
thanks for everyones help. I gave up though, it needs a new distributor or somthing, but it will just be too unpractical of a truck to have. And the engine isnt worth very much anyways so im not going to mess with it.
Old Jul 15, 2003 | 07:30 PM
phjbbu's Avatar
phjbbu
Do i have a 292?
Boo! Hiss!!
Nevaaaaah give up!
Paul
Old Jul 20, 2003 | 02:47 AM
bigwin56f100's Avatar
bigwin56f100
Do i have a 292?
A 292 exhaust manifold has a different bolt pattern than the 332. the 292 pattern is a straight horizontal line and the 332 bolt pattern is a up and down like a www not ----- the 332 also has the 2 stud valve cover bolts so dont go by that.
kevin
Old Jul 30, 2003 | 04:57 AM
caveman w/a 56's Avatar
caveman w/a 56
Do i have a 292?
try fileing your points and adjust accordingly
Old Aug 23, 2003 | 05:59 AM
f700's Avatar
f700
Do i have a 292?
hi i have a 1963 f700 tip truck with a 292 in it and a 2speed diff 5 speed boxs i put a bobcat in the back and go to work. if you want to no anythink contart me ok
Old Nov 19, 2003 | 12:40 AM
Rumblebee's Avatar
Rumblebee
Re: Do i have a 292?
Hey Superbee, you still have that motor? If you can find a casting number on the intake I might be interested in buying it.
Thanks,
Jay
Old Nov 19, 2003 | 08:11 AM
superbee's Avatar
superbee
Sure, you will probably have to take the whole truck tho If your still interested tell me a price, (ill sell it real cheap) Im not sure when i can check the casting number but ill let you know when i do.
Old Nov 20, 2003 | 12:27 AM
Rumblebee's Avatar
Rumblebee
Where are you located? I've got to see if its even possible for me to get the truck from wherever you are before I can figure out how much I can spend on it.
-Jay
Old Nov 20, 2003 | 05:04 PM
superbee's Avatar
superbee
Its about 40 miles south of Topeka Kansas.
Old Nov 21, 2003 | 12:25 AM
  #28
Rumblebee's Avatar
Rumblebee
Phew...a little far for me to travel to give it a look see (I live in Connecticut right now). so I probably am gonna have to pass on it. But, if you decide to part it out on e-bay or whatever just let me know. I'm almost positive its the manifold I've been looking for.
Thanks,
Jay
MW95F250
Feb 25, 2005 09:34 AM
atticmole
Dec 10, 2003 07:14 PM
twright05
Nov 20, 2003 12:11 AM
artandscience
13
Jul 29, 2003 09:37 PM
contento
Nov 17, 2001 07:51 PM
