1995 f150 351 problems when towing....
Old Apr 30, 2002 | 10:06 AM
DMDCART's Avatar
DMDCART
when i'm towing and have to slow down then all of a sudden i start to excellerate i have a jerking feeling in my truck like a heavy miss, it seems to happen around 1800 rpm's but not limited to that. i've changed plug wires, distributor cap, plugs ,fuel filter,flushed the injectors etc. runs fine if i'm not hauling and if i'm hauling down the freeway at around 60 mph at around 2600 rpm's it runs great...not sure what to check next any help would be great.. thanks
Old May 11, 2002 | 01:46 AM
charlez's Avatar
charlez
Old May 13, 2002 | 09:38 PM
92F150FlareSide's Avatar
92F150FlareSide
The fords were built with heavy duty trans's I have a 92 F-150 and mine does the same thing...Its just the trans...you could try to get a shift improver kit from B&M heres the webpage from summit...http://www.summitracing.com
