coolant flush
Old May 15, 2014 | 11:43 PM
redwings1951's Avatar
redwings1951
coolant flush
took my truck in for oil change truck has 206960 mi.18k on ford reman motor new radiator hoses.coolant filter he recomended coolant flush i did not even ask how there procedure was. is it possible i need coolant replaced? oh this is my dealership also degas bottle was replaced in oct. by a dealer in sd.
Old May 15, 2014 | 11:44 PM
redwings1951
oh new radiator also
Old May 16, 2014 | 05:51 AM
78fordman's Avatar
78fordman
Are you running ford gold or cat ec1 red coolant?
Sent from my leash using IB AutoGroup
Old May 17, 2014 | 02:15 AM
chewedtoothpick's Avatar
chewedtoothpick
Do you have any kind of logger to know your EOT vs ECT deltas?
Old May 17, 2014 | 02:41 AM
Matthew Anaya's Avatar
Matthew Anaya
just got my 92 ford with 306,000 miles on it, rusted water running though her, did coolant flush and changed the squealing water pump, used prestone coolant, was wondering if the ford gold was worth using or if sticking to prestone would be more ideal since its in there already.
Old May 17, 2014 | 10:33 AM
chewedtoothpick
The Ford Gold / EC1 etc discusson on the 6.0s mostly revolves around how the coolant handles the very high temps of dealing with the EGR system. Since yours doesn't have the EGR system, I don't know whether or not you have other concerns with coolant type/quality, but unless others with more knowledge chime in, I would say you should be fine.
Old May 17, 2014 | 11:05 AM
Matthew Anaya
Yeah thats what I was thinking, truck runs on the cooler side even when 100° out so not not worrying about it. Thx
Old May 17, 2014 | 11:35 AM
rjglenn's Avatar
rjglenn
The 1992 with the IDI 7.3 needs to have coolant with SCA's in it. This protects the cylinder wall from cavitation where the cylinder wall gets eaten through from the water side.
Old May 17, 2014 | 12:52 PM
Matthew Anaya
I believe that, I have a 1992 f150 4.9l L6, never bought any other coolant beside prestone as I dont have a diesel that you would want to use better coolant, wish to have a 99 7.3 f250 someday.
sgrol
6.7L Power Stroke Diesel
Sep 30, 2014 07:54 AM
mblanken881
Mar 6, 2012 04:57 AM
FSJ-EARL
Oct 29, 2010 08:08 PM
mikewrt
Jun 16, 2009 02:35 PM
PSDLOVER
Sep 28, 2003 09:59 PM
