New Toyo Mt's are c-rated?
on
Not so sure about that , you are taking a tire with a 6ply load range C rating putting it on a 7500 pound truck that requires a 10ply E rated tire and thinking all is dandy, My wifes car has load range C tires on it and believe me I would not put them on my Superduty no matter what the weight rating is, When he is pulling a nice heavy load and one of the C tires self destructs from to much heat injuring or killing someone your 18 year old lawyer is gonna get his *** handed to him...
I don't need to read it again, I get where you guys are coming from as far as the load capacity of the tire being the same as a E rated tire, what I don't get is why everyone thinks its ok to put a 6ply C rated tire on. I even highly doubt any reputable shop will do it.. Why did you go with E rated tires on your recap's Brent when you could have got by with C rated like most Toyota Corolla's have?
http://www.tirerack.com/tires/tirete....jsp?techid=55
Normally I'd post a comprehensive tire load chart that I have on my computer, but I'm traveling at the moment and don't have it handy. All the load range indicates is the maximum pressure the tire can handle, and of course the maximum load is determined from that and the dimensions of the tire. The OP's tires are rated for more than his max GAWR for both axles, which means they are perfectly adequate for the job from a load perspective. They will carry the weight just fine. They are NOT passenger car tires.
Sorry, you're wrong here. A Corolla doesn't have an LR C tire, those are exclusive to LT-rated tires. Most all passenger cars, as well as light trucks, come with P-metric tires, and there is a difference. They are NOT the sam as, nor are they even close to, an LT-rated load range C tire. In fact an LR C tire doesn't have 6 plies either, just as an E doesn't have 8. It's an equivalency to an old standard from years ago when tires had additional plies to handle more pressure.
Technical specs are subject to change without notice.
LT tires with a "C" load range have a 6-ply rating. LT tires with a "D" load range have an 8-ply rating.
LT Tires with an "E" load range have a 10-ply rating.
*Indicates Extra Load (XL)
Well Tom you are wrong , here is the specs from Nitto tires on their ply's Technical specs are subject to change without notice. LT tires with a "C" load range have a 6-ply rating. LT tires with a "D" load range have an 8-ply rating. LT Tires with an "E" load range have a 10-ply rating. *Indicates Extra Load (XL)
Here you go:
SOURCE.
Originally Posted by Town Fair Tire
Modern load range/ply ratings do not count the number of ply layers inside the tire. In fact, they indicate an equivalent strength based on early bias ply tires. Light truck tires, even those with heavy duty ratings (10-14 ply rated), actually have two or three fabric body plies, or one steel ply while many radial passenger tires have one or two body plies.
Yes that's true, an LR E is stronger than a C. But it's only an apples-to-apples comparison when you're comparing the same tire size, because the load range is only directly related to the maximum pressure a tire can handle.
For example, a monster truck only has 5-15 PSI in those big meats because it has so much surface area on the ground for that pressure to act upon. Such a tire can't even fall under the LT spec because they are incapable of even holding 30 PSI. But of course a monster truck weighs far more than a Super Duty, and those low pressure tires hold the weight just fine.
An LR E tire in the OP's size doesn't exist because it doesn't need to. That tire in LR C is rated for more weight than most LR E tires are. To put simply, you just don't need 80 PSI in a tire that size to hold 3,400 lbs. Because the tire isn't rated to 80 PSI it's considered load range C, but that doesn't mean it's not as capable as lots of load range E tires.
Can't upload it from my iPad, so here's a link to that table on my Dropbox:
https://www.dropbox.com/s/wz8ofogc63...ationTable.pdf
#28
Might stay away from lifted superdutys then. When you get to larger tires the e rated tires get scarce. And if what I take from tom is correct the letter ratings corespond to psi rating not weight rating. Ply ratings are insignificant as a manufacture could produce a 15ply load c rated tire or a 3 ply erated tire if they wished
#29
