18 volts
Old May 13, 2014 | 01:51 PM
rfchief's Avatar
rfchief
18 volts
99 F-350, 7.4 liter diesel, 225,000 miles. The last few times I started truck battery light came on and guage showed 18 volts. Voltage regulator out or what. How do I fix problem
Old May 13, 2014 | 01:59 PM
SpringerPop's Avatar
SpringerPop
You COULD just replace the regulator, but it is a job to do. You have to open up the alternator, as it's a built-in.
Since an alternator with that many miles likely has deep grooves worn into the slip rings, having a quality rebuild shop go through yours is probably the best repair.
Horror stories abound here on FTE from those who bought a "lifetime guarantee" replacement from one of the chain parts houses.
Pop
Old May 13, 2014 | 07:36 PM
River19's Avatar
River19
Pop
SpringerPop - Just so I don't end up as one of the horror stories......should I ever need a new alternator what should I avoid......more to the point, what is a good repalcement?
Old May 13, 2014 | 07:50 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
I would try to find a factory alternator and have it rebuilt. Your local alternator/starter guy usually charges around $70 which includes sandblasting & paint.
To save your voltage regulator, never jump anyone with your motor running.
Just a thought. Good luck!
Old May 13, 2014 | 07:54 PM
SpringerPop
I feel that the best replacement is a genuine OEM (they're probably made by Visteon or Motocraft) with a quality rebuild done to it.
The Ford sixth-generation (6G) alternator is a good alternator to begin with, and every part internally is available as a replacement part. The trick is knowing what rebuilder is using parts sourced from where.
There are quality parts out there, and there are junk ones, especially bearings, diode packs, and regulators. I just tell my guy "no cheap-junk parts", and I get good quality. I pay a bit more for it (maybe 15%), but I don't have problems, either.
But you've GOT to know your rebuilder!
I found a decent YouTube video on getting them apart:
Our SuperDuty trucks use the "gray" regulator.
Pop
Old May 13, 2014 | 09:22 PM
HKusp's Avatar
HKusp
Great stuff, as always Marv. I'd rep ya, but you know the drill.
Old May 13, 2014 | 09:54 PM
Bonanza35's Avatar
Bonanza35
I don't have faith in the OEM rebuilt alternators. My son went threw three of them.
Old May 14, 2014 | 07:46 AM
Whitey Ford
Quality parts are essential. A quality rebuilder will only use the BEST parts. He will warranty his work and help diagnose underlying problems with your electrical system when you experience multiple failures. Our rebuilder just rebuilt are 42 year old Electrolux vacuum motor for $35. He gave us a 30 year warranty with it.
Old May 14, 2014 | 01:54 PM
Bonanza35's Avatar
Bonanza35
Well said Mike. I was just referring to the one's my son got from Ford. He told them to put in new and they didn't. He finely went to DC power and got there 185amp and has had no problems this far. Put the last Ford rebuilt in his trailer as a spare.
Old May 14, 2014 | 03:36 PM
rfchief's Avatar
rfchief
Took it repair shop today. Replaced voltage regulator while I waited and charged me for the part only. Thanks for all the help.
Old May 14, 2014 | 04:41 PM
HKusp's Avatar
HKusp
Great to hear.
Old May 14, 2014 | 05:20 PM
SpringerPop
When I referred to "OEM Ford" and "rebuild", I did not mean what your son got.
What I meant is to start with a malfunctioning OEM Ford unit (not a Chinese knock-off supplied by a host of aftermarket providers) and have it rebuilt by a quality rebuilder, using the finest-quality parts available.
So far, not all those "quality parts" are made off-shore, but there ARE good ones made there, too! Your rebuilder will know the good from the bad. That's part of his job.
YOUR job is to know the good rebuilders from the bad, and that usually boils down to local reputation among the better mechanics in town and word-of-mouth.
Sometimes that also requires going to "have a little chat" with the rebuilder, and from that you can learn a lot about his approach to real reliability.
Pop
Old May 14, 2014 | 06:53 PM
Bonanza35's Avatar
Bonanza35
No problem Pop. I know what you meant. You going to Morgan hill this month? I'll be there, Got to have that breakfast. Maybe Clay will be there too!
Old May 14, 2014 | 07:50 PM
SpringerPop
I'd LOVE to go up, but I've got too many "irons in the fire" to make it this time.
A lot of fun I'm missing, though..........
Pop
wildwest2
Jul 30, 2018 01:52 PM
RANGER589
May 20, 2011 08:40 AM
1996 150
Apr 20, 2010 06:51 AM
JFUSION
Escape & Escape Hybrid
Oct 31, 2007 07:44 PM
dan66tampa
Jan 24, 2005 12:11 PM
