Signal light issue.
Old May 11, 2014 | 06:22 PM
CDN Sharky's Avatar
CDN Sharky
Signal light issue.
Hello again all.
So I am having trouble with my drivers side signal light it will not work. Hazards work and passenger side works but when I to the other way the flasher will not click and the display bulb in the cluster shows a very weak steady light. I have replaced bulbs, relay and the signal switch in column I am at a loss please help. This is on a mid 1978 F100 with square headlights.
Thanks
Old May 11, 2014 | 06:31 PM
fmc400's Avatar
fmc400
MSEE
Do the symptoms change between the running lights ON, and OFF?
Old May 11, 2014 | 06:34 PM
CDN Sharky's Avatar
CDN Sharky
No they don't change.
Old May 11, 2014 | 06:39 PM
fmc400's Avatar
fmc400
MSEE
Sorry to keep asking more questions without providing a solution, but does the front left running light work at all?
While it's not immediately clear yet why, it's smelling like the front driver side turn signal socket needs to be replaced. A dim, steady indicator bulb means current is back-feeding to ground through the cluster, and 99% of the time it's because the ground out at the front socket is bad. I'm expressing a little confusion because that phenomenon is usually joined by a few other common symptoms (hence my asking about interaction with the running lights), but that's most likely what's going to end up being the problem nonetheless.
Old May 12, 2014 | 02:56 PM
CDN Sharky's Avatar
CDN Sharky
Yes the running light works. I will try new socket later this afternoon.
Old May 12, 2014 | 05:10 PM
CDN Sharky's Avatar
CDN Sharky
Thank you fmc400 it was the socket you the man.
Old May 12, 2014 | 05:14 PM
fmc400's Avatar
fmc400
MSEE
Very good, glad to hear you got it worked out.
skyrader
Electrical Systems/Wiring
Aug 20, 2017 04:12 PM
7636074460
Feb 1, 2013 10:47 PM
77-400-4x4
Mar 5, 2007 11:27 AM
70_f100
Mar 6, 2006 12:01 PM
mcne
Jun 12, 2005 08:35 AM
