4x4 axle help
Old May 9, 2014 | 12:47 PM
recovery7778's Avatar
recovery7778
4x4 axle help
Have a 2000 ex v10 4x4 we are in the process of putting a new entire front end on it, tie rods, ball joints, drag bars, etc,
Were almost done we did the driver side first, no issues well the passenger side has 2 round thrust washers with a hexagon one, and a gray plastic looking on which is for the vacuum for 4 wheel drive....there all good...no wear etc...
My question there was none of this on the driver side I don't even remember there being a vacuum line on the driver side, are they missing or am i missing something.....
Old May 9, 2014 | 02:40 PM
BeachEx's Avatar
BeachEx
There should be a vacuum line on both sides, this is what operates the automatic hubs.
Old May 9, 2014 | 02:55 PM
recovery7778
Sorry I have the warn hubs not sure if that makes a difference....
Been on here reading everything from vacuum lines, axles upgrades, Dana 50 to Dana 60, did read a old post on the warn hub doesn't use vacuum..
Old May 9, 2014 | 03:48 PM
sammie0126's Avatar
sammie0126
Large one goes grove up on the back side of the seal hub unit with groves facing in - you can't see them once installed.
The three smaller ones go metal, plastic, metal on the shaft after you put the locking hub back on. Then there is a snap ring that goes on top of those three. If you don't have all 4 washers and a snap ring you have an issue.
You don't need hub vacuums if you have manual hubs.
Old May 9, 2014 | 04:02 PM
recovery7778
Snap ring is there just nothing else, ordered the washers......get to finish after the rain on Sunday....
Thank you
Dan V
Mar 8, 2014 06:47 PM
wildwheelerb200
Apr 4, 2010 12:08 PM
yotazuki
Jul 14, 2009 10:29 AM
ncm0008
Jul 5, 2009 08:15 PM
Jeff C
Jan 6, 2005 08:30 PM
